Results 1 to 10 of 10
Thread: limiter
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    yes i know there was a topic recently about rev limiters but my question is a little different. before all the shit i had to put up with from the d*ck head that last worked on my car my enigne use to rev up to 8200rpm. finally got it back this arvo still with a shit load of problems and now it only revs to 7700 like most 4age's. Can any body tell me what has happend and what has he touched he wont tell me about, since the car went in for cooling repairs? i am thinking now the fuel pump is giving shit because its not exacly like a rev limiter but more like starvation of fuel...? also am after a clean ae86 radiator asap will post thread in wanted section.
    Veteran slide86's Avatar
    Huw
    Hills
    hmm stock 4age shouldnt rev to 8200
    cannot change stock limiter as far as i know
    need aftermarket computer to be able to change the limiter.
    its probobly wise that its been changed back to 7700rpm.
    as its been said before that the power band ends at about 7000rpm
    Senior Member Shiri's Avatar
    just cause they are limited at 7700 doesn't mean that that's their limit
    toyota didn't build them to rev that far for them to be bad health after 8000
    try an apexi rsm
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    well i think i may have found the answer to my problem. supposbly the jdm computers will let the engine rev to 8200 in 1st and 2nd gear if a certain speedo wire is connected, during the many f*ck ups the people that last worked on my engine had in one of them the must of disconected it. If true this is the same wire that cuts your car off at 180k's , so if you remove it you can get speeds over 180k's with out the car cutting out but you loose 8200rpm 1st and 2nd gear. Would anyone else be able to back all this up?
    Rob
    Moorabbin
    they WILL rev higher, is it worth it? prolly not on a near stock motor
    moving the rev limit up 500rpm is suggested by club 4ag once u get some cams and a light flywheel etc
    Justin
    oh how i want all those mods... for free... now...it isnt gunna happen is it... no... *cries*
    I started the ball rolling...
    Not member #1 anymore
    Rob
    Moorabbin
    rob a bank........
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    it use to rev 8200 when i bought it, only time its ever reved 7700 was now after shit 4 brains have touched it.
    Rob
    Moorabbin
    who is this shit for brains? did HE rob a bank? or was it a rumor?
    u want more revs? put carbies on it
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    shit 4 brains was the mechanic that worked on it last. I dont want more rev's i want to be able to get the rev's i could before he touched it.
  1. hectic limiter action
    By macca1590 in forum Youtube Chan
    Last Post: 3rd December 2012, 12:34 AM
  2. Bee*r limiter.
    By corknose in forum General Topics (No Technical Questions)
    Last Post: 6th September 2010, 07:47 PM
  3. bee-r rev limiter
    By bones in forum Car Parts For Sale
    Last Post: 25th June 2010, 04:34 PM
  4. B R Rev Limiter
    By race4ages in forum Car Parts For Sale
    Last Post: 21st July 2009, 08:38 PM
