Results 1 to 10 of 16
Thread: help burning oil smell
    Default help burning oil smell
    hey guys/gals,
    when im driving my 86 , you can smell something like burning oil
    there are no oil leaks on the car
    im using castrol 10w-60
    its a 4age blue top
    is that oil just over heating?
    oil cooler needed?
    help please
    thanks
    Colin
    mine has the smallest leak from the dizzy that drips on the extractors.. u cant see it cos by the time it has had time to drip it is burned off!
    Insert witty comment here....
    ^^^ mine too!
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    Do you have a hole in your gearstick boot or anything like that....If you do, all sorts of wierdo smells make their way into the cabin...
    Maybe get a couple gauges to monitor if your worried....like oil pressure and temp...an oil cooler cant hurt but it has to mounted on the outside of the front bar.
    John 1:12
    Jay
    does it do it at start up? or is it all the time, if it does at start up then you will probably need thicker oil, something like a 20w-60 penrite HPR30
    also another good way to tell is get a mate to drive behind you and see if he can smell the oil burning , if he does then you need thicker oil
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    look on your extractors, do they have like white stains on it?
    FTP.
    Senior Member kaibeecee's Avatar
    Pete
    probably not the best thing to write there. highly illegal. looks cool, but illegal.
    also it could be your rear main seal, they often go, but get overlooked cause you can't see them
    i will have to check that out
    thanks
    Veteran Beau's Avatar
    Beau
    i've got them on my sheets.. do i have a oil leak??
    Joe
    Bellbowrie
    bahahahahahahahahaha good call, but ontopic i have same issue but only on track as the oil gets hot as fuk, need oil cooler badly
    stay classy
  1. 20v burning oil.... what could be wrong?
    By dave2221 in forum Technical - Questions
    Last Post: 19th May 2009, 01:03 PM
  2. Burning Plastic smell, Not good!!!???
    By Ksevn-T in forum Technical - Questions
    Last Post: 12th July 2008, 09:29 PM
  3. Burning smell from rear....?
    By Monster in forum Technical - Questions
    Last Post: 11th July 2006, 12:16 AM
  4. Burning oil?
    By PULSE in forum Technical - Questions
    Last Post: 7th July 2005, 08:02 PM
