Results 1 to 9 of 9
Thread: 4age into a sprinter
    Scott
    South Brisbane
    putting a fwd 4age into my sprinter soon
    I need info on the wiring side of this project.
    What can i use from the the original loom and what need replacing( i see the fuse box in the engine bay has hte efi stuff there..does this mean that wiring is there??or do i need to add it to to plug)
    Im getting an Aw11 mr2 loom , should this be all the wiring i need, also some plugs are missing off it .. can i get these from an auto electrician>?? plugs missing are the COR N1 and the one that connects to the fuse box
    any guidance , help or websites would be muchly apprieciated!!!!!
    Mar 2005
    http://toymods.org.au/Repository/TechDocs/...ook/elec_wring/
    not sure if that will be of any help or not bro...
    cant wait till u get this running.....look forward to cruzing with ya..
    sa
    victor harbor
  • #4
    Jason
    Broadbeach
    the wiring for the efi is already in the fuse box, all u will need for there is a relay. Just get it off any toyota. It is M4.
    A wiring loom needs to be made up to run across from the ignition to the computer. So long as everthing in the loom plugs in all should be sweet.
    Depending on your location there are a couple of people that would be able to do this.
  • #5
    Scott
    South Brisbane
    sweet
    thanks guys (ive already found those sites but cheers ne ways)
    so i wont have to add any new loom in the engine bay>> just the cabin
    im living in brisbane but doing the conversion in Lismore coz my dad has a shed..
    is there any one around Lismore who is keen do do some wiring...hehe
    just got the AW11 MR2 and the and the AE86 4age ECU pin identifacation. Quiet a few differences when when you compare each pin..Should be able to work them out .
  • #6
    Scott
    South Brisbane
    Just read a heap out of Max Ellery's engine manual
    makin a lot more sense now
    >>Still a few things im uncertain about:
    >>will ahve to remove the sprinter loom, add new wires then put the loom back in ...or will i be able add new wires with the loom intact?
    >>Does any one have an ECU pin diagram for the 4ac ECU so i can compare them to the coloured wires of the new 4age ECU
  • #7
    Jason
    Broadbeach
    I'm not exactly to sure what ur saying there, but the loom that is in the car (4ac) does not need to be pulled out the car and rewired.
    I can get Sam's no. for you if u like just pm me. He might be interested, or might not as he lives in Brisbane. He wired up my car and everthing is great.
  • #8
    Senior Member riceburner's Avatar
    Um dude you should not be under going this conversion without some serious help and/or guidence
    4AC dont have ecu's their carby motors.
    Insert witty comment here....
  • #9
    Paul
    Gold Coast
    Wink
    You can leave the 4ac loom in the engine bay. That shits there for stuff like water temp, oil pressure, reverse lights etc.
    Just plug everything you can into the engine and then run the loom through the bung in firewall and plug the ECU in. All you should really need to do is then hook up a 12v source to the ecu for power. Cant remember the pins but you'll need 2 need switched and 1 pin needs a constant. Make sure all the earths are good and that the ingnitor has 12v and kick it in the guts. I'm sure theres a few things ive missed but its not too hard if you have a bit of knowledge about electronics.
    I wired up my 4age myself with both the standard ECU and the Microtech. Both times there were a couple of little problems, but just little things you miss. Don't forget you will also need to wire up the alternator. Do a search on Toymods, theres a thread there telling you what colour goes into the standard loom.
  • Similar Threads
    1. AE86 SPRINTER 4AGE
      By wesso in forum Cars for Sale (Toyota Only)
      Last Post: 22nd January 2013, 06:39 PM
    2. Sprinter with 4AGE QLD
      By Poobrown86 in forum Cars for Sale (Toyota Only)
      Last Post: 10th February 2009, 10:43 AM
    3. ADM 4age sprinter
      By Grommet in forum Cars for Sale (Toyota Only)
      Last Post: 9th January 2008, 08:53 PM
    4. 4AGE into an aussie sprinter
      By ATXBoy in forum General Topics (No Technical Questions)
      Last Post: 3rd November 2005, 06:09 PM
    5. sprinter with 4age
      By federal in forum General Topics (No Technical Questions)
      Last Post: 22nd May 2005, 11:14 PM
