you are going to be a busy boy arent you...
good luck mate
OK change of plans... thanks to OPTION1 im getting a JDM shell with a sunroof already stripped bare so a lot of parts will be needed.
the plan is to turn it into this...
So far the plans are (keep in mind this wont be street registered)...
Engine: 4AGZE
Oil Cooler with remote filter
FMIC
2.25 or 2.5 inch straight pipe from front to back
Pulley Kit
Internal Work
Cams
Fuel pump
Injectors
ECU
Suspension:
Tociko custom coilover setup front with Cusco Camber plates
Tociko rear adjustable dampers
Custom springs
Sway bars
Strut bars
Driveline:
T series rear end (drum to drum for now... might upgrade to s13 bits further down the track)
Kaaz 2way LSD
Lightened flywheel
HD Clutch
Body:
Completely gutted
1 fixed back and 1 recliner
Full race style cage
Custom gauge cluster (no dash)
Exterior:
Stock at first (custom kit later on with guards front and rear, custom bonnet and hatch as well as front and rear custom bars)
15 or 16inch Work EWING rims
Im estimating about 18months before it is fully ready to the way i want it...
Only thing i will do until i have all the other parts is the suspension... then i will start hitting the prac days and building it up from there.
Hoping to have the LSD and suspension in by about august...
So yeah... finally starting to happen and i cant friggin wait... ever since i got the taste for it in december at banzai its all i can think about
good luck mate
I started the ball rolling...
Not member #1 anymore
go hard my son.....let the 86 be wit you....... plans are solid....hope it all works out for you.
have fun
yeah thanks guys...
gutting and stripping the sound deadner next weekend...
will get the suspension in about 3 months if the soarer sells by then (hopefully earlier), rear end and LSD in august.
should be enough to get it on the track.
may need an engine
yeah sounds like u have it all planned. goodluck
thats exactly how i got pulled in, a mate in his sprinter showed me the art of drift, and i became an addict instantly.
your plans sound mad! should be a neat project to watch as time passes.
just a personal thing, i think it would look good (and different) if it were painted yellow and black panda, black bottom half. then put your graphics over it. its just an opinion.
i might mess around in paint and see what i come up with.
hey dude, sounds like its gonna be nice !
i reckon you should paint the door yellow aswell, but keep the roof black !
Theres something about a dead stock sprinter that turns me on .... Soo many options all custom to yourself. Best of luck mate i hope it all goes well
lol im getting the engine this weekend.
worked 4AGZE with 120kw at the wheels... should be good in a 900kg car
when the proper paint goes on, those doors will be fibreglass as will the hatch and coated in a special black chrome that monkey has been telling me about... but thats a while away
