Hello
I was hoping that someone can help with my question. I have a factory RWD intake and T/body with no TPS. Do I need a RWD TPS or can I use a FWD TPS. If not is there any reason why I can't use the FWD T/body and TPS that I have also. Just to make thing clearer I am fitting an AE82 4age to my Sprinter.
I hope one of you guys can help
Todd
I think as long as the connection between ur tps and the connector on ur loom fit toghther, it will work.
Well thats what happened with mine. I Had a JDM 4ag, it was missing the the tps.... so i bought 1 from interstate, unfortunately the connections between the tps and the loom weren't the same. So i had to get another 1.... just went to a wrecker and found the tps with the same connection as my loom. And obviously the 4ag it came off was FWD.
hope this helps.
