Results 1 to 5 of 5
Thread: cams for na stock 4age
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default cams for na stock 4age
    hi all iv ot a question for all you tech gurus whats the longest duration cam you can put into a 4age running a stock ecu and head
    i have heard of a 265 being the biggest you can run on a stock ecu by Sprinterman68 himself but i called camtech today for an inquiry and they said that the 265 was the standard duration on the 4age im a little lost so this would be a great deal of help
    cheers all
    the dyno pull to 300rwkw
    Gone
    Joel
    Picton
    256 is not the standard duration at all,
    Cam Timings -
    Inlet Cam - Duration - Lift
    'Big port' 240 7.56mm
    'Small port' 232 7.1mm
    4AGZE 232 7.1mm
    Exhaust Cam - duration - Lift
    4AGZE 232 7.1mm
    256' is the most lift u can run on a stock ECU
    Mt Macedon
    Have a search on Toymods, I'm pretty sure a friend of mine (cnich82 or similar login) whacked some 272 cams in his stock 4AGE and said they worked and made an improvement. A few years back, so I' mnot sure of details, but he did write something about it.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    yeah 265 is apparently the max duration u can use with stock ecu, but if aftermarket prob alot more of a higher limit like 300's
    i had 272 8.3lift intake ex is unknown spose to be 288 at this stage in a stock bigport
    the thing hammered didnt have problems.
    ae71 parts for sale stripping 3xae71's and a ke70
  1. cams in a stock bigport?worth while?
    By s13 james in forum Technical - Questions
    Last Post: 16th October 2012, 11:09 AM
  2. na cams in gze
    Last Post: 10th January 2009, 02:22 AM
  3. Stock black top cams
    By Poobrown86 in forum Technical - Questions
    Last Post: 15th August 2008, 11:54 PM
  4. na na na na na na na na na BATLEB!
    By snake in forum Offtopic Discussions
    Last Post: 8th November 2007, 10:05 PM
