Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Gearbox specs
    Kieran
    Default Gearbox specs
    hi guys,
    just wondering what gearboxes came in which cars like what gear boxes came in each of the xe7x's and what cars would i find t-50's and w5x's in?
    and what are the specs of each
    thanks
    Veteran shift_rook's Avatar
    SE Burbs
    w5's corona's and supra's probaly more aswell(celicas aswell i think)
    t50's AE71 T18's ae86's. that's all i can think of at the moment
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    Is the T18 T50 slightly different?
    Different input shafts or something?
    Senior Member adam's Avatar
    Adam
    T18 T50s have a 20 spline output shaft compared to the AE71/AE86's 22 spline. Not sure about input.
    TA22s also had T50s, but are pretty shit to be using in a E7 or 86 from what I've read. Wrong shifter position etc.
    More info in this thread,
    http://ae86drivingclub.com.au/forums...hlight=gearbox
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by adam View Post
    Absolutely correct.
    Corona
    Anything pre RT104 uses a W40, Some RT104's have W50's.
    XT130 - Borgwarner, good for nothign
    RT132 / RT133 - W50
    ST141 - Borgwarner, good for little apart from 3S conversion
    RT142 - W55
    Celica -
    TA22 - As above, T-50, not suitable A Motor application (T motor only)
    RA28 - W50 / P51
    RA40 - W50?
    RA60 - W55
    SA63 - W55
    RA65 - W55/W57
    Supra -
    MA40 - W50
    MA61 - W58
    GA70 / MA70 - W58
    JZA70 turbo - R154
    JZA70 non turbo - W58
    JZA80 turbo - V160 / V161
    JZA80 non turbo - W58?! (steel case version?!)
    Jonathan
    The Celica is fully imported, so SA63 box is a W series.
    RA40 is mechanicaly the same as RA23/28, so W50 yes.
    Early T18 has same output spline as TA22 and KE30.
    Late T18 has same output spline as AE86.
    The TA22 box can be used, either for parts, or a replacement gearbox if you swap some parts over.
    Josho
    Above posted edited to reflect new info. Thanks johnny.
    Kieran
    and what is in the corollas?
    Jonathan
    What Corolla?
    Josho
    Quote Originally Posted by squish_m8 View Post
    KE10 - K40
    KE20 - K40
    KE30 - K40
    KE55 - K40/K50
    KE70 - K40/K50
    AE71 - T-50
    AE82 onwards - FWD
    Early (pre KE70) K50's will not suit KE70, the extension housings are different. You can swap them if you want. I didn't list corolla because i thought it was common knowledge.
  1. Specs
    By benbertucci in forum Technical - Questions
    Last Post: 24th June 2009, 03:43 PM
  2. torque specs
    By ae86ln in forum Technical - Questions
    Last Post: 29th April 2009, 01:21 PM
  3. headbolt specs
    By dustyae86 in forum Technical - Questions
    Last Post: 18th September 2007, 02:39 PM
  4. power specs
    By dori king in forum General Topics (No Technical Questions)
    Last Post: 25th January 2007, 07:20 AM
  5. power specs
    Last Post: 24th January 2007, 11:43 PM
