w5's corona's and supra's probaly more aswell(celicas aswell i think)
t50's AE71 T18's ae86's. that's all i can think of at the moment
hi guys,
just wondering what gearboxes came in which cars like what gear boxes came in each of the xe7x's and what cars would i find t-50's and w5x's in?
and what are the specs of each
thanks
Is the T18 T50 slightly different?
Different input shafts or something?
T18 T50s have a 20 spline output shaft compared to the AE71/AE86's 22 spline. Not sure about input.
TA22s also had T50s, but are pretty shit to be using in a E7 or 86 from what I've read. Wrong shifter position etc.
More info in this thread,
http://ae86drivingclub.com.au/forums...hlight=gearbox
Absolutely correct.
Corona
Anything pre RT104 uses a W40, Some RT104's have W50's.
XT130 - Borgwarner, good for nothign
RT132 / RT133 - W50
ST141 - Borgwarner, good for little apart from 3S conversion
RT142 - W55
Celica -
TA22 - As above, T-50, not suitable A Motor application (T motor only)
RA28 - W50 / P51
RA40 - W50?
RA60 - W55
SA63 - W55
RA65 - W55/W57
Supra -
MA40 - W50
MA61 - W58
GA70 / MA70 - W58
JZA70 turbo - R154
JZA70 non turbo - W58
JZA80 turbo - V160 / V161
JZA80 non turbo - W58?! (steel case version?!)
The Celica is fully imported, so SA63 box is a W series.
RA40 is mechanicaly the same as RA23/28, so W50 yes.
Early T18 has same output spline as TA22 and KE30.
Late T18 has same output spline as AE86.
The TA22 box can be used, either for parts, or a replacement gearbox if you swap some parts over.
Above posted edited to reflect new info. Thanks johnny.
and what is in the corollas?
What Corolla?
KE10 - K40
KE20 - K40
KE30 - K40
KE55 - K40/K50
KE70 - K40/K50
AE71 - T-50
AE82 onwards - FWD
Early (pre KE70) K50's will not suit KE70, the extension housings are different. You can swap them if you want. I didn't list corolla because i thought it was common knowledge.
