Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 10 of 65
Thread: Power Figures.
    Default Power Figures.
    Sup gents would be cool like old dc to see what were all gettin on the dyno.
    Dont have a scanner for the mean while though this will do.
    stock smallport with a filter and 2000yr old exhaust that is fucked.
    http://au.youtube.com/watch?v=1HmBM-CfvE8
    Sutherland
    I just had my car dyno'd today so here are the results.
    Engine: Black top 20v, TRD 0.8mm Headgasket, T3 Trumpets, Haltech E8
    LS1 Coils, 3.9kg Flywheel.
    Power: 108rwkw@9100rpm.
    Tuner: Scott Hilzinger from Haltech.
    It kept making power but I cut it at 9100rpm for obvious reasons. It is a super
    clean tune and highly recomend Scott for tuning.
    It sounds insane at those revs.
    Veteran slydar's Avatar
    Dimitri
    thats nice work on the bt.
    carefull revving it that hard though. ive replaced one blokes BT who used to rev it that high... leg out and all. was funkdocs car. fair few sprint days ect but yeah. 8.5 might be smarter
    Quote Originally Posted by wideslider View Post
    damn, thats good power...cant wait to see wat mine does
    Moderator Frak's Avatar
    Jamie
    ae111 20v bt on mainline dyno, i.mec ramtubes, minor mods, 100.35 fwkw.
    max power at 8400rpm.
    dynoed before and after fitting rams(same day, within 30 minutes), below 3200 rpm picked up 3kw, from 3200rpm to 4100rpm runs along standard curve then pulls away for an extra 6kw at peak. no losses with short rams.
    Dimitri
    ahh nice. i have those ram tubes laying around for my brothers car, good to see they make good numbers.
    anyway, hoepfully ill have something to add to this thread in the next few weeks.
    have - 16v 4age. big port head. 20v bottom end, with small port pistons, pair of wade cams, and some of the 4-1 headers i sell. will be running the engine in on stock ecu, and then changing to carbs, probably mikuni phhs.
    Jonathan
    If people are going to list their engine setups they used, I am most interested in cams used, and cam setting used. (Very interested if you got high power). And have much less interest in what computer or coils are used. And if you rev to 9100rpm, then I would be interested in what conrods, and what valve springs.
    Sutherland
    Hey Jonny, I'm taking it to 9100rpm with stock everything bar TRD headgasket.
    It revs cleanly there with no signs of valve float, I drove an AE111 which had no limiter and it regulary saw first gear changes to near 9500!!!
    So far everything is dandy but if it decides to shoot put a leg out of bed I'll let you all know.
    User fantapants's Avatar
    Pat
    hey johhny, dont discount the importance of the comp and tune man.... it certainly aint the be all and end all, but a good comp and a great tune will snap a well bult engine and mad cams that is tuned on a mappable camira ecu by duncan the donut eater
    ps welcome to the chafers man.... if you need cheapie bits let me know i have some grouse hookups in tassie for the lycra ladies
    06/07/2011
    Pat
    ps forgot to add mine...
    healthy silvertop, very short trumpets.. like those above, motec with ecu rev limit at 8700 i think.... pulled th pin on the dyno at 8500, was still making power but almost flattening... 104kw.
    have to sort a few things out for the tune man and he wants another go as im still a bit rich up top and in the middle under partial throttle.
    didnt have any other trumpets to try but am workin on a plenum to look a little less defectable. will play with both those and show any changes.
    also tuned on bp ultimate with 4.8 - npot sure if that make a difference. if i missed any important info let me know what i need for next time.. ill take notes
    06/07/2011
  1. Japanese Ae86 Models & Figures
    By Teddy in forum Other Items for Sale
    Last Post: 20th March 2011, 12:25 AM
  2. 4agte power figures? which turbo?
    By Nic19 in forum Technical - Questions
    Last Post: 15th March 2010, 10:50 PM
  3. Power figures
    By 4AGE - 86 in forum Technical - Articles
    Last Post: 30th September 2008, 05:08 PM
  4. cam shaft figures
    By hillclimb86 in forum Technical - Questions
    Last Post: 15th July 2007, 06:35 PM
