Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 21 to 30 of 65
Thread: Power Figures.
  1. #21
    Paul
    I would have to have a look at the data log but I think that it was making 6psi around 3000rpm and full boost around 4000rpm. Like I said though it think that I might have a little boost leak somewhere. I will have to measure the boost at the turbo compared to the inlet. I am not too fazed about numbers because every dyno is different. The thing certainly feels strong enough, it is up there with my old turbo mx5 and that had 190rwkw on a different dyno
  2. #22
    Reeece
    Casula
    full boost @4000 with a t25 is not right me thinks.. Check your cooler for leaks or even your waste, boost controller ..
  3. #23
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    MAP sensor 4AGZE from AE101 rolla Levin
    Autronic SMC computer
    Custom RMS PWR cooler
    Custom RMS plenium
    Custom RMS PWR 3core rad
    XF throtel body
    Custom install of SC14 charger from 1GGZE motor
    Now have fitted and soon to have
    TRD Copy extractors ceramic coated plus new 2.5in exh with "free flowing" cat and muffler
    Need a new smaller charger belt as this one aint tight enought and slips. I can get 11psi some times but that run was at 7psi more often than not,
  4. #24
    Senior Member 45aken's Avatar
    Marko
    what the shit happened past 130kw??
    belt slip?
  5. #25
    Justin
    DC
    Downtown
    USA
    yup... Plus, I just asked him to print off the most recent one as i was in picking up some other bits as he was mid tuning.
    Its a pig in the wet lol
  6. #26
    Paul
    Yeah, I will be doing a couple of road runs in second in the next day or two, I will data log to see how it goes. It doesnt help that my MAP sensor hasn't been calibrated spot on. If I change it though I will have to do a retune.
    Paul
  7. #27
    Senior Member lach's Avatar
    Lachlan
    Neds
    pulled a massive 100.2hp atw's with stock big port with safc and exhaust. Does that seem normal or a bit low? dyno has history running a little low on poer figures.
  8. #28
    Moderator Frak's Avatar
    Jamie
    That's 74.6kw.....that's VERY good!
    on our dyno(mainline) bigports pull around 65kw(87hp).....give or take a few.
    Hachiroku since 1994
  9. #29
    Senior Member Intense's Avatar
    Aaron
    96kw on a bog stock ae101 4agze, stock exhaust with big leak from the manifold and chong feng spec filter. Throttle wasn't opening 100% either due to slack at the pedal, fixed now and I'll attend another dyno day in the future to test my gains I'll have made.
  10. #30
    Lachlan
    Neds
    awesome, thats good to know then, just got into 86's a few months ago and wasn't sure on power figures.
  1. Japanese Ae86 Models & Figures
    By Teddy in forum Other Items for Sale
    Last Post: 20th March 2011, 12:25 AM
  2. 4agte power figures? which turbo?
    By Nic19 in forum Technical - Questions
    Last Post: 15th March 2010, 10:50 PM
  3. Power figures
    By 4AGE - 86 in forum Technical - Articles
    Last Post: 30th September 2008, 05:08 PM
  4. cam shaft figures
    By hillclimb86 in forum Technical - Questions
    Last Post: 15th July 2007, 06:35 PM
