Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 61 to 65 of 65
Thread: Power Figures.
  1. #61
    Veteran blair's Avatar
    Blair
    SEQ
    no internal mods? fresh motor?
    Trying to figure out what i should be aiming for with my fresh 20v/16v 'combo'
  2. #62
    Member 88skip's Avatar
    Jamie
    South brisbane
    well motors done 95xxxk's not sure if its been rebuilt. and nah no internals
    Never loose respect of what your doing behind the wheel!
  3. #63
    Akio
    Mt Haruna
    Japan
    anything between 80-90rwkw is going to be quick blair. you should get a mad mid to high range power, with enough poke down low not to make it a massive pig.
    heres mine:
    built smallport
    fully balanced bottom end
    hi comp pistons (12:1)
    "race" head work (dont know exact specs, but god damn its awesome)
    kaizen TRD copy headers
    crushed exhaust (long story, cbf'd to fix it now)
    stock cams (massive limiting factor. pretty much doesnt make any more power after 6500rpm)
    ported intake manifold (irish spec)
    stock single throttle body
    3.7kg fly wheel
  4. #64
    Jamie
    South brisbane
    nice! your cfm looks alot better than wat mine did on one of the other ecu settings,
    it made 106.4 hp and cfm was all over the place. once i rember were i put the damn things ill take pics of them both
  5. #65
    Jul 2009
    shaun
    nsw
    port macquarie
    got a re tune on mine after i changed exhaust as it was press bent and not mandral also put longer trumpets on the car, have a bt 20v, rsr extractors, 272 cams, haltec e8 computer, sr20det coils that about it and i made 128.2hp ill get dyno sheet up asap
    also i made about 610 lb of torque is this a good torque figure????
  1. Japanese Ae86 Models & Figures
    By Teddy in forum Other Items for Sale
    Last Post: 20th March 2011, 12:25 AM
  2. 4agte power figures? which turbo?
    By Nic19 in forum Technical - Questions
    Last Post: 15th March 2010, 10:50 PM
  3. Power figures
    By 4AGE - 86 in forum Technical - Articles
    Last Post: 30th September 2008, 05:08 PM
  4. cam shaft figures
    By hillclimb86 in forum Technical - Questions
    Last Post: 15th July 2007, 06:35 PM
