Results 1 to 1 of 1
Thread: Front shocks.
    Senior Member Ksevn-T's Avatar
    Default Front shocks.
    Hello,
    bought a pair of KYB rally shocks with the intention of putting them in my xt130 struts. I was under the impression that xt130 struts are pretty much identical to ae86 one's?
    Once i had pulled out the stock inserts i found that the new Ae86 specific front shock inserts would not fit, as in i couldn't do up the gland nuts because i couldn't get the threads to meet. So my questions are: Is there other gland nuts you can purchase to fit? Is there any machining that needs to be done, eg. Machining of the shock cartridge and gland nut, or even strut? Has anyone else encountered this problem?
    Also, Maybe a silly question but, when running chopped front springs in the front end. Does the flat side of the spring sit on the bottom (chopped side on top) or the top (chopped side on the bottom)?
    Cheers,
    Alex
  1. Front shocks
    By egg_83 in forum Cars or Parts Wanted
    Last Post: 7th February 2009, 08:01 PM
  2. 2 front shocks, help me decide
    By AE86.cn in forum Technical - Questions
    Last Post: 5th June 2008, 10:47 PM
  3. front shocks
    By drftr86 in forum Technical - Questions
    Last Post: 8th February 2008, 04:00 PM
  4. ke70 front shocks
    By keto in forum Cars or Parts Wanted
    Last Post: 28th September 2007, 09:02 PM
  5. Front shocks
    By kiwi in forum Technical - Questions
    Last Post: 24th September 2007, 01:07 PM
