you need a sprinter (T50U clutch plate...you will most likely also run into trouble when it comes time to bolt the box and motor together....the pressure plate should hit the bell housing....iv got bellhousing to suit a T50 here that has been mchined out to accomodate the bigger flywheel...
regards
jesse
