Results 1 to 5 of 5
Thread: 3D Models - Autodesk Inventor
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    Default 3D Models - Autodesk Inventor
    I just thought I'd share a few rims I built while ago practising my parametric models with Inventor 2008 Pro.
    They are mostly scaled to be about 15x9 -15. Note brake disc and caliper assembly.
    If you use Inventor or maybe another design package like Unigraphics, Solidworks or Pro-E post your works
    Site Supporter Javal's Avatar
    Josho
    I modelled a working 5.0L Quadcam V8 a few years back with autodesk 9.0 when they had it at my high school...
    I'll have to download it again and make up something better.
    Jonathan
    I am currently updating my computer skillz with a AutoCAD 2009 course, but I have done 3D in AutoCAD previously. My course only covers AutoCAD, but will probably jump on Inventor shortly. I hope it's easy enough to learn.
    What is your real-world use for Inventor other than a graphic? A graphic is nice, a real drawing that can be used is totaly different thing.
    I am thinking of using Inventor to model a AE86 (or any car) chassis and suspension and steering geometry. A moving working assembly, with accurate geometry. Move the suspension up and down, measure the bump steer, pinion angle etc. I gather Inventor is able to do this.
    Karl
    S.A.
    Austria
    I'm sure if you build it accurately and constrain the assembly, you could find the ranges of motion. The thing is you'll only be as accurate as your measurements, as you probably won't have dimensioned drawings to work from. so measuring everything will take the longer then actually drawing it. There is a program called SUSPROG which is ideal for analysing suspension behaviour.
    Who is running the course, is it at TAFE or by Autodesk? It's pretty easy to go from AutoCAD - Inventor, but when you do you'll proabably think I should have just gone straight to 3D modelling. As it's more intuitive to make something, then create the drawings from the Model rather then combine the views to generate a solid. It's always good to know both methods.
    I work as a mechanical engineer in the Defence industry, so real world use for it is design and simulation, everything from components to complex assemblies and structures. Also do Finite Element Analysis, rapid prototyping to precision machining.
    When I started technical drawing I learnt with T-squares and circle templates and 0.3mm, 0.5mm, 0.7mm, 1.0mm pencils and pens! Then used a number of CAD programs over the years.
    The models above started out check clearance with caliper/disc combinations that would fit in my rims, then I made other styles just for fun
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i could of used that in CAD last yr lol
  1. Models/Dioramas?
    By 86TRD in forum Offtopic Discussions
    Last Post: 24th June 2009, 12:41 AM
  2. Corolla models?
    By R&D Mechanical in forum Offtopic Discussions
    Last Post: 11th May 2009, 12:47 AM
  3. you like ae86 models?
    By ae86hachiroku in forum Toyotas in the Media
    Last Post: 2nd September 2007, 10:56 PM
  4. Anime models.
    By flamingheads in forum Offtopic Discussions
    Last Post: 15th September 2006, 07:00 PM
  5. GT Models
    By Celica RA45 in forum Technical - Questions
    Last Post: 21st August 2006, 10:41 PM
