Page 9 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 81 to 90 of 102
Thread: Genuine Part numbers, How to get new parts for your 86
  1. #81
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    windscreen rubbers ? are you talking bout the external trim ( plastic/rubber coated metal) or the neoprene type seal that holds the front windscreen in ? the seal is out of a tube that all windscreen fitting places use on nearly all cars, the bits of trim you should get the part number from toyodiy.com, then order it through your toyota dealer if its still avail'
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  2. #82
    Senior Member shawn_26's Avatar
    Shawn
    Southside
    Yea just the external trim. Mines a bit warped, and letting a fair bit of water sit under the seal, which is not ideal I guess you could say.
    edit: Just looked at toyodiy.com. That website is gold! Thanks heaps for that.
  3. #83
    Veteran blair's Avatar
    Blair
    SEQ
    ^ just fill it full of goop?
  4. #84
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi Shawn
    2dr Boot rubber should be p/n 64461-12230
    no windscreen rubber it is glued in.
    Hope this helps
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
  5. #85
    Mark
    Southern
    no worries.. just remember a lot of the part numbers listed are old occasionaly susperceeded and quite often the have not been added to the australian parts list
    the top front windscreen trim part number for an adm hatch is
    75531-12270, its about 60$ as ive bought one before, i think they would be the same for all models of ae86
  6. #86
    Adz
    requesting p/n for T50 output seal AE86 JDM
  7. #87
    Senior Member cbjaust's Avatar
    Do you mean the seal that is at the output side of the extension housing - that's the part where the gear shift lever goes in? If so try Part No 90311-32010. See .
  8. #88
    Jason
    Gold Coast
    Anyone know the part no. For a ae101 gze head gasket? retard at Toyota is telling me 101's only came with silver tops.
    I'm half tempted to carry my engine down and drop it on his counter.
  9. #89
    Veteran Nikkojoe's Avatar
    Tom
    4agze use a standard 16v head gasket
  10. #90
    From
    GASKET, CYLINDER HEAD
    11115-16070 4AGZE..AE101; T=1.25 1 $64.26
    The Gasket for the 16V is listed as 11115-16030 with no mention of thickness.
  1. Genuine Parts, Part numbers
    By Jonny Rochester in forum Technical - Articles
    Last Post: 11th September 2008, 12:42 PM
