Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Parts required for 4AGE in to KE70, parts only, no instructions
    Default Parts required for 4AGE in to KE70, parts only, no instructions
    Copied,
    i can see this question being asked more than once. here is a list of the parts required to do the conversion, if i have missed anything let me know and i'll update the post (its 10:26pm and i have been at work since 4, thats 4 this morning which means i got up a 3 to get to work )
    AE86 or AE71 engine crossmember
    AE71 gearbox x member (86 one can be used)
    AE71 pedal box
    AE71 or AE86 clutch master cylinder
    AE71 or AE86 solid clutch line from master to slave, and rubber hose
    AE71 or AE86 rubber engine mounts
    AE71 or AE86 steel engine brackets
    AE71 or AE86 gearbox stays (link box to block)
    AE71 tailshaft if keeping the ke70 borg diff
    AE86 tailshaft if using S series
    AE86 tailshaft with T18 back half if using T series diff
    T50 gear box
    obviously a 4AGE of some sorts JDM being easier, ADM FWD being a little trickier but no big deal.
    thats just what you need to get the engine in there, you will also need
    modify tank pickup with fuel pump, plus mod top tank plate with a 8mm fitting for fuel feed.
    fuel hose (injection spec)
    loom to suit, either modded AE82 loom if using a bigport, modded AE92 loom if using a smallport, or a slightly less modified JDM loom again if you are using a bigport.
    Davey & Riki-lee
    South Australia
    Seaford SA
    and what acc cable do you use if you have a ke70?
    The stock one seems to be too long, or can you still use it?>
    Elite rthy's Avatar
    Leo
    Tulla
    i used a ke70 cable as the ae71 is too short (same as 4ac ae86's)
    its looped around the cmc
    also u will need the ae71 t50 crossmember (not sure if u can use the k40/50 member?)
    (AE86 on the top, ae71 bottom)
    with the cmc, holes will need to be drilled into the firewall
    more info here:
    http://www.rollaclub.com/faq/index.p...draulic_clutch
    for Auto conversions the shifter hole will need to be wider
    ae71 4ac radiator, both rad in and outlet is on the same side for the 4ac, ke70 rad will need some extention
    also since i used a fwd motor i used a electric thermo fan
    also pics of said 4a rwd engine mounts and gbox stays
    ryco Z200 universal efi fuel filter with a 4ac coil mount to look stocky
    note: it has 8mm nipples
    the stock ae71 lines fuel lines are 6mm and 4mm return
    VL Fuel pump, mounted with 4ac coil mount used lol
    would prefer intank fuel pump but this will do for now
    if you can upgrade to ae86 struts and brakes
    will need the whole ae86 struts (springs, shocks, brakes, etc...)
    use the ke70 strut top and ae86 steering arm (get jdm if u want more lock lolz)
    Wiring 4age
    http://club4ag.com/faq_and_tech_page...86%204A-GE.htm
    Another thread on alternator wiring found here
    http://www.ae86drivingclub.com.au/bo...howtopic=29433
    *Assuming bigport* When using my info, Refer to Club4AG AE86 ECU pinout/wiring diagram
    Other then that:
    -give ignition power to positive terminal on coil (usually a black/orange wire which connects to the ballast resistor on the old coil which you can use [I did], but you can make your own relay to power coil using the black/orange wire as an ignition trigger)
    -On 14 pin plug, Pin 7 (+B1) and Pin 14 (+B ) can be connected together, and go to ignition (or can come off a relay you used for coil power)
    -On 14 pin plug, Pin 6 (Batt) goes to constant battery 12V source (ie wire straight from positive terminal on your battery if you want)
    For fail safe starting, you may also need to give power to injectors (Yellow wire found on 10Pin plug, Pin 10 (BF)) by joining a wire into the yellow wire and giving it 12V on iginition (again, use the same relay that you may have used for coil, but might be drawing too much current).
    There ARE other ways to do it, and probably make it neater and more factory like but that works.
    Fuel pump relay setup (if you dont have a factory COR relay).
    Alternator
    http://www.rollaclub.com/faq/index.p...Wiring_Diagram
    Other links:
    http://www.rollaclub.com/board/?showtopic=5644
    http://www.blognow.com.au/project86/
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by AE70 View Post
    I used an EP92 starlet cable, depending on the manifold though you may need to shorten the cable inner wire. The outer sheath is right on though.
    Dave
    The Ghetto
    very helpful article, should make this a sticky
    Gearbox stays are not really needed, but if you have them, definatly use them.
    I used an Odyssey Linear Slick BMX brake cable as my throttle cable, works well.
    Jon
    Durack
    PM slydar
    he is a wizard at 4age's
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Quick question, Looking at gettin an AE71, 4AGE's bolt directly in correct?
    Veteran slydar's Avatar
    Dimitri
    yeah. the engine will mount using the stock mounts and transmission. 20v will need the dizzy moved or the firewall clearenced.
    Aaron
    In the Mountains
    you should really use a surge tank or get a jdm fuel tank or you will get fuel surge when the tank is low going around roundabout/thrashing etc.
    for this you require a small low pressure lift pump to fill the surge tank then a main EFI pump (VL etc) to pump from surge to engine.
  1. clearing all corolla ae71/ke70/ae86 parts also 4age parts
    By tuff te-72 in forum Car Parts For Sale
    Last Post: 26th May 2011, 01:08 PM
  2. 4age smallport parts and ke70 conversion parts
    By ionise in forum Cars or Parts Wanted
    Last Post: 10th September 2010, 08:33 PM
  3. Replies: 5
    Last Post: 17th May 2010, 02:23 PM
  4. Parts required for 4AGE in to KE70
    By Gilly in forum Technical - Articles
    Last Post: 2nd October 2008, 12:42 AM
  5. Medwin's Parts Required Thread
    By medwin46 in forum Cars or Parts Wanted
    Last Post: 21st November 2007, 10:55 AM
