Results 1 to 4 of 4
Thread: In tank wires
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    Default In tank wires
    what wires can i use for my intank lifter pump
    Nathan
    Lilydale
    go to the wreckers and pull out wiring out of another tank. i used vl intank wiring.
    The insulated coat on standard wiring will degrade over time in petrol.
    hope this helps!
    Ethan
    North Suburbs
    hey man got calvin to get me some outta a VL so all good
  • #4
    Jonathan
    I don't know much about this, but 1st year Chemistry knowledge would help a lot. It is basically about what plastic the insulation is made of.
    Cheap general use automotive wire is PCV, polyvinyl chloride. I am told this is not good enough for high heat or solvents, good for 85 degrees.
    Next one better is crosslinked polyethylene, or SXL etc, which has a much higher heat resistance 120 degrees, and resistance to solvents. Not sure if it's good enough for fuel or not.
    Best would be telfon or ETFE? Or Rilsan® Polyamide 11 & 12? I know very little about this. But best go to a auto electricial place rather than a general store, and ask them for different types.
  • Similar Threads
    1. igniter wires ?
      By loc33e in forum Technical - Questions
      Last Post: 2nd May 2008, 11:32 PM
    2. tacho wires
      By lewwy in forum Technical - Questions
      Last Post: 13th October 2007, 05:17 PM
    3. Mystery wires
      By bigm in forum Technical - Questions
      Last Post: 7th June 2006, 06:46 PM
