y do u want to take it off? its glued to the body probly break it before you get it off
I took the indicator (the one next to the parker) off and tried taking the lense off the body but couldn't. Is there a trick?
How to most people paint them with the lens paint? Do they paint the outside? I thought you had to paint the inside.
pretty sure u can just spray the tint on the outside man... just give it a good clean with turp ect and then spray away.... u may wanna hit it with some clear coat after............
i pryed mine off the parker..they have like a blue-tac type sticky shit sealing them on to the parker..a few screw drivers you'll be right..i painted the inside of mine very very lightly with some matt black i had lying around..just one or 2 squirts at about 30cm away..total internal reflection will fill in the bits you don't do..so don't try and black them out completly..just a fine mist will be plenty..and you might want to put in a slightly higher watt bulb..
