Results 1 to 10 of 11
Thread: Removing front springs
    Default Removing front springs
    Is there a way to remove front springs without using a rattle gun for the top of the suspension tower?
    i've only ever done it with a rattler.... Now i dont have one and need to take them out!
    Veteran bigm's Avatar
    Gold Coast
    use spring compressors to take the pressure off the tophat then might be a bit easier,
    if not
    find a compressor
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Spring compressors are a must, fuck that shit flying out.
    And if you don't have a rattle gun on the top hat, you're probably going to have to put multi-grips or vice grips on the shock shaft to try and stop it spinning. I've only ever done them with a rattle gun aswell.
    Senior Member adam's Avatar
    Adam
    Reinstall strut back into the car, put wheels back on and take it off jacks. Open your bonnet to get access to the shock nut, undo it. Take out struts, everything should just fall out..
    As you jack the car up, the springs will push the struts down so the spring won't hit your face or anything like that.
    ^that's awesome thanks guys!
    E-Famous (Remeber your roots)
    Your car isn't low enough if you have front springs (not coilovers) and they are compressed
    What adam said is a good way to go about it.
    Tried the Adam method but the struts are still spinning, any way to cure this ?
    Mark
    hammer!
    Hold the spring onto the perch with multi grips, this is what I always do.
    But the struts are usually out of the car.
    Ok round 2
  1. removing front rotors
    By subaer in forum Technical - Questions
    Last Post: 17th June 2009, 11:52 AM
  2. Removing front windscreen
    By marco in forum Technical - Questions
    Last Post: 17th April 2008, 08:17 PM
  3. removing front guards
    By driftster in forum Technical - Questions
    Last Post: 28th September 2006, 08:42 PM
  4. removing front bumper
    By ke25 racer in forum General Topics (No Technical Questions)
    Last Post: 30th May 2006, 06:45 PM
