Now thats done pull up carpet(if you still have it) and remove the four (in total) rubber plugs
Ok, for those of you that don't know hear is a little walk through on how to remove the stock rear bar off your sprinter (aus spec)
You need to undo the bolts near the mudflaps and also take off the mud flaps(if fitted)
the ones on the other side
now you will need an 19mm soket with extension to undo these as they are pretty tight, we also used a bit of leverage to help
Undoing the bolts
Now you've done that there are two more, one on either side behind the trimming
Hear is a pic with the bolt removed
and the other side
Then with a little wiggle you should be able to pull it off!
And this is how she will look after about 20min work(if that)
Don't forget to unplug the plate lights as well.
