Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 10 of 108
Thread: Johnny K's AE85 Trueno Coupe
    Senior Member Johnny_K's Avatar
    kiara
    1984 AE85 Truneo Coupe
    Motor:
    AE92 smallport port and polished head
    Toda 0.8 metal headgasket
    HKS 272 intake 272 exhaust 8.1mm lift cams
    HKS valve springs
    Adjustable Cam gears (no names from japan)
    ARP Head studs, conrod studs/bolts and mains
    AE92 block acid dipped
    Shot peened AE92 conrods
    Stock AE92 pistons with new rings
    ACL race bearings
    Crank,pulley, flywheel, rods, pistons blablabla have been dynamically balanced
    Intake:
    AE101 quads with trumpets (short)
    Kaizen Garage quad Adapter (awaiting delivery)
    Exhaust:
    None atm lol but planning to get some nice stainless steel design
    ECU:
    Adaptronics (being wired up now)
    Driveline:
    JDM T50 gearbox
    Toda lightweight flywheel roughly 4kg
    Xtreme heavy duty clutch
    T18 diff with 4.1 final gear (soon to be 4.3)
    Kaaz 2-way LSD
    T-Series driveshaft
    Suspension:
    Front Adjustable Coilovers: 8kg/mm AJPS Springs with AGX 4way adjustable shortstroke shock
    T3 Camber Tops
    6kg/mm AJPS rear springs with Camaro shortstroke shocks
    Front and rear strut braces
    JDM Calipers with RDA vented, slotted rotors
    Rear whiteline swaybar and adjustable panhard rod
    Corona front lower control arms with new bushes/ball joint
    Tune Agent Traction brackets
    Still running stock 4 links but with poly bush
    PS steering arms
    AJPS Bolt on lock spacer
    Soon to be added suspension wise
    Front whiteline swaybar
    RCAs
    Cusco tension rods
    Wheels:
    15x7.5 Longchamps (pair)
    15x7 0 offset Konig rewinds (set)
    14x7.5 -2 offset SSR mesh (pair)
    Body:
    Dodgy fibreglass bonnet
    Vertex Front Bar
    Interior pretty much stripped (except for dash and fixed bucket drivers seat with 4point harness)
    Sound deadening removed throughout, including firewall
    Home resprayed by my mate and myself in Cusco Blue
    Homeflared front and rear guards
    Safety 21 6 point roll cage (through the dash!)
    Ian
    NOR
    love the steering wheel
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    love it, but how can u drive with such a gastly steering wheel...
    hotness.. apart from the steering wheel lol. nice
    Yang
    Salisbury
    That is one clean engine bay. Looks good, first one i've seen in red
    kiara
    Hahahahahaha i had a feeling i would get replies about the steering wheel, the only thing i like bout it is the trueno badge on it , other than that its shit to drive with. Hopefully it will be replaced soon
    Jul 2009
    wow, thats actually very clean! the first pic didn't turn me on, but as i saw more and more the better it looked!! good work!
    Rob
    Moorabbin
    very nice! how you like the suspension?
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    hell yeh! thats neat as! Looks like abit of a weapon
    Oldschool Member
    Aug 2005
    another sik AE dressed in AJPS goodness, hes gettin a bit of rep.
    very clean looks hot as
  1. Matt's AE85 Trueno Coupe
    By 85Kai in forum AE86 Owners Forums
    Last Post: 5th August 2013, 04:38 PM
  2. Jeremy's 3SGTE ae85 Trueno
    By d-shiznit in forum AE86 Owners Forums
    Last Post: 29th May 2007, 08:55 PM
  3. AE85 Trueno coupe
    By lo_rolla in forum AE86 Owners Forums
    Last Post: 22nd December 2005, 12:05 PM
