Results 1 to 6 of 6
Thread: windscreen replacement
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default windscreen replacement
    does anyone know a guy who actually makes custom windscreens for a living ? need one for kouki ae86, dont bitch and say their all the same and im able to get it from a local windscreen joint, if u got access to one its 3cm difference in height,
    first person who gets me an actual source that is willing to do it gets $20
    david.
    Dan
    Vic
    Western Subs
    national windscreens in footscray
    tell them daniel from VW parts said you could help him out
    . h i t o r i k o .
    Senior Member stanzzza's Avatar
    stanza
    west
    3cms, 1.5cms at each end is sweet fark all.
    theres more then plenty meat left to silicon the windsheld in.
    Senior Member blacktopspirit's Avatar
    Brendan
    Eastern
    just make sure you keep a window open when they do fit it.
    with that much silicone, you close a door and huge pressure builds up and pops a hole through the silicone, either causing it to leak, or causing moisture to to build around bare metal surfaces, usually where the windscreen blokes have scratched paint getting your old screen out.
    I had this problem in an XF panel van, they put an XG screen in, 4cm difference apparently, so they just compensated with Silicone, windscreen place ended up having to remove my screen fix all the rust around the area, and put in a new screen at no cost!
    Dave
    Western Suburbs
    im sure if those windscreen blokes felt it was safe just to jam silicon inthe gap of the bottom they woulda jus to get the money, was 3cm or 3inches roughly something like that its been a while since i been trying to chase this but i jusgot into some strife so i need it now, but back on topic dont want any shit fights over the net just want some sources to chase up this week
    Dan
    Vic
    Western Subs
    call national windscreens in footscray speak to peter - 96876222 have all the measurements of the car screen and he'll help you i called this morning and spoke to him he is expecting a call - just say your daniel @ vw's mate and he'll look after you
    . h i t o r i k o .
  1. Strut Replacement
    By Snowman in forum Technical - Questions
    Last Post: 21st December 2007, 11:55 PM
  2. Replacement Panels
    By julzy in forum General Topics (No Technical Questions)
    Last Post: 21st June 2007, 12:40 PM
  3. Alternator replacement
    By howee in forum Technical - Questions
    Last Post: 14th July 2006, 01:27 PM
  4. Replacement radiators
    By .wolfwood in forum Technical - Questions
    Last Post: 23rd June 2006, 01:19 PM
