Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 45
Thread: Recommend Engine Oil?
  1. #11
    Poh
    Bevo
    castrol magnatec (bigport)
  2. #12
    Jul 2009
    Penzoil Multi vis 20/50 in 4AFE, 4AC (mates car)
    Penzoil Street machine 25/50 in new project revs motor..
    have tried various semi synthetics 10/40, 15/50, 20/60, found mineral 25/50 to be the best comprimise because up here in the middle of the day it gets F$%#ING hot and oil turns to water thin..thats when engine failure occures....
  3. #13
    Jul 2009
    have to say Penzoil is the best stuff i have used..
    Penrite turns black after only a few hours use.. dunno why but it's quite smokey too.. even for such a thick oil... like 20/60..
    wouldn't touch Castrol or anything thin or semi synthetic on a non rebuilt engine.., only on very fresh rebuilt 4AGE's, and low KM 20v's...
    everything else i'd use a 20/50 or 25/50 if it's got a little higher in the km's...
  4. #14
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    So whats recommended for a 4ac with 200k on it using a bit of oil?
  5. #15
    Julz01
    I use Castrol GTX in the 4ac
  6. #16
    Jul 2009
    i'd hit it up with a bottle of stree machine 25/50, see if that stops the smoking, if not top up the oil a bit with a little Lucas Oil Stabilizer.. this shit is awsome!!! makes oil soo thick and gooooooey...my rings were completly stuffed in my old GZE, this gave it another 6mts driving! and didn't blow smoke..
  7. #17
    Jul 2009
    i'm in brisbane, and i find that most other oils get tooooo thin on 40 degree days.. thats why i run a thicker oil...
  8. #18
    Travis
    Blue Mountains
    Thanks mate. Its due for a change so i'll chuck some of that in it and see how it goes!
  9. #19
    Yang
    Salisbury
    I use HPR 15 Semi Syn 15w/60. I also use a K&N Oil Filter
  10. #20
    Jul 2009
    i just went to supercheap on boxing day and bought half a dozen Z386's, my idea is if you change the oil and filter frequently enough the more chance you have of your engine lasting.. usually change the 86's oil every month or so.. cheap insurance if you ask me.. oil only has to go too thin for a few seconds to cause irreversible damage..
    also with oil filters.. ryco or valvoline ones are perfectly fine.. most other brands are good also, as long as they have an anti-drain back valve you can use it fine..
  1. Oil for running in engine.
    By Mickey H in forum Technical - Questions
    Last Post: 18th September 2009, 10:55 PM
  2. recommend an oil cooler
    By The Enthusiast in forum General Topics (No Technical Questions)
    Last Post: 17th June 2009, 07:01 PM
  3. 4age engine oil / T50 gearbox oil
    By pogi in forum Technical - Questions
    Last Post: 27th May 2009, 11:27 PM
  4. Engine Oil?
    By ke70dave in forum Technical - Questions
    Last Post: 1st August 2008, 02:18 AM
  5. 4ag engine oil capacity
    By jdmcoupe in forum Technical - Questions
    Last Post: 5th October 2007, 11:01 PM
