Kaaz Powertrain gear oil for the diff
Redline Lightweight shockproof for the t50
sorry to hi -jack ur thread but, what brand of diff & gearbox oil do u guys use ?
diff - Penrite 10ths competition oil
g/box - Detron III auto trans fluid no particular brand.. what ever is on special..
Engine -- 10w50 Valvoline Synpower
Box -- 75w90 Valvoline DuraGear
Diff -- 90w Valvoline HD Synthetic
Brakes -- Castrol SRF
Clutch -- Valvoline RBF
Later
Chris O
what does tha box feel like wit auto dexron III in there .. same or better ?
shifts are sweet!! 3rd gear used to grind and crunch all the time.. no matter what manual box oil i put in there.. a toyota tech mate of mine suggested this to me.. i thought bullshit.. but no, it really does work! some manual boxes even specify running an auto fluid..
lsd diff- what oil
you would know this, do you experience any clutch fade due to the fluid reaching its boiling point come to the end of the race?
i know it wouldnt as u use nice fluid, but have you ever had it happen?
DOT 4 should be enough for a non racing sprinter should it not?
DOT 3 should b alright too
I am currently using HPR 15 (15W/60 Semi Syn) and it doesn't use much oil but people tell me my car does blow smoke and I will be idling at the lights or when I park in the garage I will smell this bad smell. Could that be because the oil is to thin?
