Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Castor chopped guards.
    Senior Member Ksevn-T's Avatar
    Default Castor chopped guards.
    Hey guys,
    Running a fair bit of Castor in the front of my ke causing the front wheels to scrape on or bend the guard. When cutting the corner of the front arch off do you have to run that little strut that holds the guard to the chassis? or can you completely get rid of it? How much do you need to cut off? Anyone got pics?
    Cheers,
    Alex
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    you cut off as much as you need to, to run as much castor as you want. dpmt meed that mount. you dont need pictures. get the angle grinder and start cutting!
    FTP.
    Dave
    Quote Originally Posted by Clinton View Post
    best answer ever
    start cutting, you'll know when youve cut enough....cuase it wont rub....
    also why run so much castor! make the steering so heavy.
    make sure you paint where you have cut, so it doesnt rust.
    User fantapants's Avatar
    Pat
    i have just upped my castor massively, and the stearing is sooooooo much lighter than it was ... not sure why, was expecting a little heavier...
    Quote Originally Posted by ke70dave View Post
    best answer ever
    06/07/2011
    Senior Member resol's Avatar
    steve
    vic
    Quote Originally Posted by fantapants View Post
    then maybe u didnt up you castor
    or you fiddled with the toe settings, or put different steering arms in as well?
    either way more castor = heavier steering, more grip and win
    gunner:
    ALL DRIFT MODIFICATIONS
    Calvin
    Kilsyth
    maybe he means steering is lighter for drifting because the wheel will do most of the work itself
    T18 in the build
    Pat
    changed to brand new tune agent castor rods... shortened by about an inch... basically set as short as possible.
    nothing else was changed and the car def needs a decent wheel alignment, but yeah much muahch lighter on the stearing.
    06/07/2011
    Andrew
    Quote Originally Posted by resol View Post
    There is a diminishing return though, just because 4 deg is better than 1 deg, it doesn't necessarily follow that 8 deg will be better again. I wouldn't go dialling in 10 deg of pos caster straight away and cutting the guards to suit. Try 4 deg, then 5 and see if there is any discernable benefit. If there isn't leave it. If there is, go another degree and see if there is any improvement again. Etc.
    Too much caster as well as being a waste of time, will pull the outside of the LCA forward too much causing the arm to bind and flog out the bush. You might find that this happens before the handling stops improving, meaning you need to mod the LCA pivot.
    Veteran Konakid's Avatar
    Henry
    Eastern
    ^^True, or get rose jointed arms + tie rod ends.
    Kieran
    i know its a noob question but what is castor?
  1. WTB: AE86 front springs. Can be stock/chopped
    By Beige_Hornet in forum Cars or Parts Wanted
    Last Post: 7th February 2012, 09:15 PM
  2. 210mm 6kg front springs not chopped Bris
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 13th August 2011, 12:15 AM
  3. SA: $50 - front and rear chopped springs
    By Barnsey in forum Car Parts For Sale
    Last Post: 9th August 2010, 07:38 PM
  4. chopped springs
    By buzzin in forum Technical - Questions
    Last Post: 25th March 2009, 09:50 PM
  5. chopped springs
    By DRFT - 86 in forum Technical - Questions
    Last Post: 23rd May 2006, 11:51 PM
