Results 1 to 6 of 6
Thread: Machining Flywheel!!??
    Ade
    SYD, Inner west
    Default Machining Flywheel!!??
    hey people,
    next week i will be replacing my clutch, so i was thinking that while the box &
    clutch are out that i might get the flywheel machined.
    i only have a 4AC. so don't know if its worth the hassle.
    So is it worth it?
    how much will it cost me?
    and anyone know where i can get it done in the inner-western sydney area?
    *edit...(sorry should of put this in the tech q's section. someone please move this)
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    i'd only bother machining it if it's black and/or got scores but if it looks to be good then dont bother.cost a mate like $60 at a brake shop. yellow pages for a local brake shop then give em a ring.
    id machine it then u wont have to worry bout it.
    for the $30 it cost me i do it lol
    abs in qld does all mine sr or 4ac/4age and never had a prob
    when you do a new clutch shouldnt u machine the flwheel anyway?
    ae71 parts for sale stripping 3xae71's and a ke70
    You should definately machine the flywheel when you replace your clutch, if you don`t you will end up with a clutch that shudders every time it engages, especially if it has burn marks on it (blue patches).
    性交を愛する
    I'd get it machined.
    marvis.
    Ade
    SYD, Inner west
    the clutch i will replace the old one with is 2nd hand.
    will this be a problem?
    has plenty of meat.
  1. Replies: 149
    Last Post: 31st August 2011, 01:24 AM
  2. Who do you use for disc machining?
    By slydar in forum Brisbane & QLD Events and Discussion
    Last Post: 6th August 2011, 02:17 PM
  3. machining and polishing rims?
    By Mr Awsome in forum Adelaide & SA Events and Discussion
    Last Post: 17th September 2010, 07:41 PM
  4. machining shop to do stub axle swap
    By nath in forum Technical - Questions
    Last Post: 22nd March 2007, 08:17 AM
