There you go sunny
Hi guys,
I'm going to paint my sprinter factory Red and Black. Like the panda but Red/Black instead of white/black. Anyway, anyone know the genuine Toyota colour code for them?
Thanks
There you go sunny
Thanks Dorio86
The code is 2T6, which means red with the black bottom.
The red used is probably 3E6, and black is just black, but can use 202.
Do you know if the black paint that I use on the body can be use on the bumper? will it stick to the plastic bumper and won't peel off after a while? Do I need to get special paint for the bumper?
Paint it with plastic trim primer first, should be fine then. If you are having it professionally painted, they could probably add some extra flex agent to help it stick to the bumper even better.
