Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: Info on F series diff ratios above 4.3
  1. #11
    Anthony
    petrol and diesel both have that ratio in certain versions. You can trust the diff code on the build plate with 4wd's generally because they would have to change both front and rear for it to be different. unlikely.
  2. #12
    Veteran slydar's Avatar
    Dimitri
    on the build plate it should have 1 letter and 3 numbers.
    you need the front diff out of a 4x4 hilux. the build plate i think only lists the rear if i remember correctly.. the code for the rear will be GXXX, first 2 numbers are the ratio code. check them against the list above and thats the ratio. front and rear ratios are the same.
    toyota ring gears will have the ratio actually written on them.
    sometimes its just the number of teeth. something like 41 11.
    or just the actual ratio in a circle, like 4.8 with a circle around it. thing to note here is when its written like that, the figure has been rounded. eg my t series 4.778 has 4.8 written on it. but the code on the car was T362.
  3. #13
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    wicked!! im fairly sure that diff you gave me said 4.3 in wrecker writing how acurate would that be man?
    AE86 THE BEST
  4. #14
    Dimitri
    and sorry should have explained, in that list, the ratio ive written first, then a space, then the 2 digit code for that ratio.
    so 4.444 is 11
    4.625 is 12
    4.556 is 25
    those are the numbers youre looking for.
  5. #15
    Anthony
    yeah it was 4.3 for sure. ive got a 4.7 for mine this time. to go with w58.
  6. #16
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Removed caps for you
  7. #17
    Eddie
    sa
    ooooh thats why i didnt get it hahaha
    AE86 THE BEST
  8. #18
    Eddie
    sa
    4.7 sheesh tats prety serious but might have to go to that!!! you dont have any 4.5 lying around up there do ya?
    AE86 THE BEST
  9. #19
    Eddie
    sa
    well i just went to a comercial wrecker who imports toyota ratios and he was saying he had a 4.7 ratio which got me excited so after alot of measuring and realising the 4.7 was smaler than a f maybe a t or an e he had what he said was an oddball 4.55 ratio, after trying the axle and comparing it to my 4.3 centre it turns out the centre he had was a 4.55 f series. so theres another one to add to the list there is a 4.55 solid axle centre diff available!!!!
    AE86 THE BEST
  10. #20
    Glenn
    North Ringwood
    the 4.55 is called a 4,6 they are also 4.78 and 4.88 availible as well brand new crown and pinions are about 450 aussie
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  3. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  4. techno pro spirit t series diff ratios
    By pen15 in forum Car Parts For Sale
    Last Post: 23rd March 2010, 01:27 PM
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
