just want to clarify one more thing...
i read in here that u can get centres from the front of hiluxs,etc
will the front ratio be the same as the rear??? in theory they should be but is there something in the tranny case that makes a difference???
4.556 > code is 25... pretty sure that list is fairly complete.
either way, got what you need now?
yes front and rear diffs r the same ratio.
not sure slydar have to try it i neede to try either 4.55 or a 4.77 to see what i need. will see how this onw goes then may need to go to 4.7
AE86 THE BEST
sweet so if i ind a good ratio code on the compliance plate i flog both centres
i like this alot... going to 4wd wrecker tomorro
i have the trans axle code of a 07 diesel hilux and saw an f in the code and dont get how this code works so the knowledgeable let me know.
trans/axle a340f bo1b
AE86 THE BEST
up to the top for all those that were away on the weekend
AE86 THE BEST
up to the top again
AE86 THE BEST
no good eddie, the f is part of the auto transmission code. the diff is b series, incompatible.
that code doesnt make any sense to me.
the next biggest size diff after G is A, and that is what i would expect in the rear of a late diesel hilux, but yeah i couldnt tell you if the front diff was gonna be f series or not.
but yeah that code doesnt make sense to me.. or set out how they usually are. maybe if you took a photo of the build plate i could help but yeah later stuff is a bit strange sometimes.
eg's for say, a ta22 celica, which will have a 4.1 t series. code will be T292
another eg, say, mid 80s tarago, mostly are e series 4.3, they will be E282
to get an F series out of a 4x4 hilux, usually earlier stuff is G series rear, so it might be G282, if its G series rear it will be F series front, front and rear ratios will be the same, so you can assume with some level of certainty that the front diff is a 4.3 F series.
78's
Also remember that all rear Hilux's are G series, independent fronts are different, could be worth looking at the code for an independent front, should be F series. They are different front and rear.
I got nothing.
