What does she rev at 100 with 4.7's with the w58???
damn thats the exact cod i read off the plate next to trans/axle oh well i was excited was an o7 hilux
AE86 THE BEST
ive got an IFS hilux ill check the diff code tomorrow
I've got a 4.5 shimmed lsd that I'm wanting to swap for a 4.11 if that interests you? I'm not 100% sure if it's an f or g series though. Is there a quick way to find out?
I wouldnt do that.. those early hilux's with the solid front end have a G series Rear.. but F Series front..
pretty sure you couldnt have a shimmed lsd if it was g series.
also ant how necessary do you think 4.7 is with a 58? I have a 55 in there till i finish the car and can afford a nice 58, but if the center needs to be changed id rather have that good to go before I get it all back together, its a 4.3 at the mo.
wheelfriends.wordpress.com
hard to say. 4.3 will be fine, I just wanted to get the same overall ratio as the J160 in 2nd with 4.3 was as I liked it. I guess with the W58 and a 4.3 it would just be a little quicker. probably not such a bad thing.
