Results 1 to 2 of 2
Thread: Coilpack Testing
    Oldschool Member
    Jan 2006
    Hey lads,
    I got a multimeter and i want to test my coilpacks how will i do that on my 20v silvertop.
    I was think just unplug all the leads to the coilpacks.
    And have a mate connect the multimeter to each coilpack as i try to crank it over so it will create a spark and just make sure all the readings are the same over the two coilpacks.
    What sorta voltage am i looking for on the multimeter?
    - Luke
    Jonathan
    To test coils, unplug everything. Don't try and start car or anything like that. Use the multimeter on the resistance setting. Test the resistance of the primary, and secondary windings. If you at least have a reading (or very low resistance), then that is a start.
    On a twin coil, the little plastic plug (with two sires going back to harness or igniter) is the primary winding.
    The two big ends for the plug leads if the secondary winding, which is not directly conected to the primary winding.
    Is this car already running? Not a unfinnished project? You have the right igniter and computer?
  1. coilpack plug
    By evil86 in forum Technical - Questions
    Last Post: 5th December 2011, 08:22 PM
  2. 4agze coilpack plugs
    By trikzlane in forum Cars or Parts Wanted
    Last Post: 15th April 2011, 12:02 AM
  3. 20v dizzy / coilpack
    By ae86 in forum Technical - Questions
    Last Post: 20th November 2009, 09:01 PM
  4. CA18DET coilpack cover
    By paulie in forum Car Parts For Sale
    Last Post: 13th July 2007, 01:10 AM
  5. Coilpack Seemingly Cactus
    By gumbie in forum Technical - Questions
    Last Post: 10th June 2006, 04:28 PM
