So cheap. But auto
Have fun.
SPECS
base car- beige 81 model (auto)
engine/driveline. 7rib big port 4age, full rwd ae86 accesories. stock ae86 ecu, KAIZEN GARAGE modified (4age) ae82 loom requires only a single solder joint within the engine bay (alternator wiring combined into loom) coil and igniter in cabin.
grifted 3 puck clutch and custom nicks clutch cover 200mm flywheel.
AE71 t50 with AE71 gearbox x-member
86 clutch pedal(does not bolt in, requires modification) and engine x-member
AE71 clutch master cylinder
adm 86 tailshaft
locked S series
KAIZEN GARAGE headers and clutch hose
KAIZEN GARAGE exhaust system ( sleeper spec)
front - 14x6.5 +10ish watanabes (paint stripped back to raw) wearing potenza g3s
back - 14x6.5/7.5 miss matched pair of long champs
front suspension
coilovers out of my 86 (swift springs, trd inserts, cusco tops) with jdm brakes and braided brake lines
sigma LCA
T3 RCA's
rear suspenion
TRD springs
shox- KYB excell G suzuki siera fitment
inside nardi classic, tacho dash, heater box, vent fan and centre console removed.
jdm ae86 power steering knuckle arms.
quaife quick rack.
78's
So cheap. But auto
Have fun.
auto just means i dont have to pull the cable clutch pedal out. ke's are cable clutch, so to run a 4ag/t50 you need to change the pedal anyway.
78's
i think you have to change the whole pedal box dude. i had to change mine but it wasn't originally auto. also the ae86 gearbox mount won't work all the holes are different, again mine wasn't auto originally, so the above info could be wrong!!!
if you want to offload the rear seat i'll take it i need some other interior parts too, depending on how much you want to strip it.
pm me if you want to get rid of that shit, how's the wheel hunting going, found some for me?
good to see another beige one getting around!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
i have been speaking to a bloke up in townsville whyo is willing to supply me every single part i would need out of an ae71 including x-member, engine mounts, gearbox, everything. its a little bit of cash that i dont want/need to spend if i dont have to.
i could sell the gearbox but its money tied up and i have f*** all atm.
im also pretty sure people have used 86 hardware to do the hydraulic conversion before. the car should be here tomorow so i can have a good look.
i sell you the rear seats for sure. im sure we can agree on a price i wont want much at all.
78's
I used all AE86 shit in my conversion. pedals/engine crossmeber and gbox crossmember. You just have to elongate the holes a little for it to line up.
did you drill new holes for the crossmember? i just modified the stock one. are you talking about the pedal box or the pedals? my ke70 pedal box had absolutely no provision for the mastercylinder at all. mumblezz you have an AE71 don't you? i think thats where the difference is as they already have hydraulic clutch.
ke70 beige is the same colour as super crap primer filler. what does that mean? no top coat thats what.
78's
where's these pics you were talking about the other day? get em up!!!
Best make that three
But I got the slant front
Thank god I got one at all
All Beige Everything
