Best chance you will have is to take the cam belt cover off and get the part no off it. I can't remember the number of it at the moment
what timing belt can i get for the 20v 4age in australia?? its not the same as the 16v ones im guessing?
The belt construction is different and the blacktop has 1 less tooth.
Sprinter Veteran
ST- so its not the same as 16v ya? can i find this belt in australia?
I'll check today at work and try to find it
Going by the computers at work it should be T081 (111 X 20) which retails for $39.99 from Gates Timing Belt
or just ask for a timing belt to suit a Lada Samara
aahh thanks guys.
was suppose to startup the engine in the car yesterday just to reliase when i was filling water that i didnt bolt tight my waterpump. flooded my garage
how hard was it for u to find tha right water pump for tha 20v
