Results 1 to 8 of 8
Thread: JDM altenator 4A-GE
    Senior Member Brendan's Avatar
    Brendan
    Default JDM altenator 4A-GE
    need one aye, mines fucked, got it tested today and she wont charge...
    needs to be a rwd jdm one
    thanks guys
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    same as any fwd 4afe alternator man......... recoed ones goe for around $180, thats the cheapest I could find....
    I was actually getting it for my daily (seca) and after I did I realised it was the same as the one off the JDM engine I had..
    On that note, I have a silvertop 20v one you can have for $50... will just have to change the plug that connects to it, no big drama.
    BENT MECHANIX - Garage 20:
    Brendan
    ah ok yeah just the pulleys different yeah? Or am I thinking of 4ac? Yeah sounds good dude, do u have the plug aswell? If not I could just use blade conectors yeah?
    Where you located mate?
    Nathan
    Lilydale
    I think your right, the main difference between the FWD and RWD (jdm and adm) pulley components (waterpump, alternator, crank) is that the belt sits furthur forward of the motor.
    so assuming you can just swap the pulleys on the alternator, most 4age/4afe fwd alternators should be compatible i suppose!
    I can get a FWD 4age bigport one if you like.
    nath
    Veteran Nikkojoe's Avatar
    Tom
    Its the waterpump which is the only problem. All 4age alternators, fwd or rwd are the same. Also 7m I think fit (same design), but the terminals are in a different position.
    Nathan
    Lilydale
    ahh thats makes more sense, disrigard my last post! cheers nikkijoe
    Niz
    South~Slide Briz
    Quote Originally Posted by Brendan View Post
    yeah as stated there is no issue with the pulleys.....
    pretty certain I have the plug also....
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    u can use also an st182 altenator which gives u more charge power aswell
  1. RWD JDM 4A-GE Intake Manifold (SA)
    By ADM_86 in forum Car Parts For Sale
    Last Post: 12th March 2010, 09:11 PM
  2. 4a-geu ecu pinout same as ae82 4a-ge?
    Last Post: 25th November 2009, 05:21 PM
  3. jdm rwd altenator brackets
    By pen15 in forum Cars or Parts Wanted
    Last Post: 22nd May 2009, 02:34 PM
  4. Unifilter Air filers, 4A-C Carb on 4A-GE manifold
    By asher in forum Car Parts For Sale
    Last Post: 15th June 2007, 08:16 AM
  5. 4A-GE head onto a 4A-C Block??!?
    By ironmonkey in forum Technical - Questions
    Last Post: 10th April 2007, 08:47 PM
