Results 1 to 5 of 5
Thread: datto stud pattern
    Sep 2005
    Will rims off a datsun 1200 fit on a hachi that I'm looking to buy? I don't want the rims that are currently on the car, and my mate has some nice rims off hisa datto up for grabs
    Jan 2006
    you might want to measure the rim offset
    the pattern is 114.3 x 4 as per the sprinter but 1200 offset could be anything ?
    Will
    i had a 1200 for a while.
    the standard rims on it would have been at least 3 inches wide.
    if the offset if anything like a 1600 then they should fit OK. just trial fit one on the front of your car.
    Oldschool Member
    Apr 2005
    Qld
    From memory most old school datsun wheels are 4x114 so they will fit in that regard, just check the offsets.
    I currently have a set of 14" 240z mags in my shed which fit up fine. Pretty much same offset as standard rims.
    Best way to know is trial fit them to your car. Be sure to double check the fitment at the front as you may have scrubbing issues.
    tye
    nsw
    wollongong
    I previously owned a 1200 sedan and currently use 14 by 6 " wheels off that on the rear of my ke70 as hack rims ..they are 4by 114.3 same as sprinter but are not sprinter friendly offset ..datsun 240/260 are a much better offset . hope this helps a bit mate .
  1. stud pattern adapters help
    By Dowsett in forum Technical - Rims & Tyres
    Last Post: 4th November 2011, 07:51 PM
  2. Changing to 5 x 114.3 stud pattern
    By Low Style in forum Technical - Questions
    Last Post: 21st April 2010, 08:45 PM
  3. STUD PATTERN & OFFSET
    By the_kid in forum General Topics (No Technical Questions)
    Last Post: 24th May 2007, 05:41 PM
  4. Anyone got torana stud pattern?
    By HighLife in forum General Topics (No Technical Questions)
    Last Post: 14th November 2006, 10:29 PM
  5. Stud pattern on a oz-spec sprinter
    By HYPNTK in forum Technical - Questions
    Last Post: 7th September 2006, 07:17 AM
