a 16V 4AGE with quads is one of the best sounds that can ever be created.. listen to mine..
Does the 4age sound different under high revs with those trumpets? because i know the bigport has a unique sound at high revs i was just wondering if it has a louder noise or somethin.
cheers,
Yes it does have a louder noise and a much sexier noise aswell
omg you're alive!
quads with a small peashooter zaust = horn
but did u have extractors matty....
yep.. 4-1 off the shelf ones for now.. 2.25" mandril system that i used on my 13 sec GZE is all retained, with a new cat and 1 muffler... extreamly loud.. but it's the only way i'd have it!
how loud u think a cannon on a bigport would be? 2 inch cat back pipe i think i got
depends on the way the exhust is set up.. mine pretty much goes straight.. with a few soft bends and under the diff.. if you have the pipe going into the muffler on a slight angle it makes it a bit quieter as it blows into the side.. even if it is straight out it should work and not be insanly loud... it's hard to explain my muffler.. it's a 5 " round muffler with 2.5" in, and 3" flared to 4" tip.. it's not really a cannon as such actually a round muffler.. and if you look inside a muffler you will see little bent scolops that catch the air/noise and make the muffler work.. mine only has about 3" of that.. then there is a gap like a chamber, then another 3" but facing the other way.. stops it from buzzing and poping downhills like a riced up honda civic..
how much clearence do u get with an under diff exh?
bout 6 " on mine.. but you have to have super short shocks so the diff doen't smash the exhaust during normal travel.. or when you jack it up..
