Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: upgarage's AE86
    Ian
    NOR
    probably other shit which ive forgotten but here goes...
    Specifications
    Car:
    1984 Toyota Sprinter, Australian Spec
    Engine:
    CA18DET
    Stainless steel high mount manifold
    Custom oil/water lines, braided oil feed line, heat shielded. made by Enzed
    RB20DET turbo with internal gate bolted shut
    K&N pod filter
    Full stainless intercooler piping
    Turbonetics Deltagate Mark II with screamer pipe
    Stainless steel 3"dump
    Full 3" exhaust with HKS Silent Power Muffler
    Oil catch can
    600x270x76mm Intercooler
    Rom'ed CA18DET ecu
    Drivetrain:
    Xtreme 8puk clutch and pressure plate, Standard CA18DET Gearbox, Custom made one piece tailshaft, Jap T Series Disk Brake Rear End, TRD 2 way LSD, 4.3:1 Ratio.
    Fuel system:
    Japanese spec efi fuel tank, Jap efi fuel lines, CA18DET Fuel Pump.
    Brakes:
    Jap spec front ventilated disk brakes with tokico pads
    Jap spec disk to disk rear end with EBC pads
    Wheels:
    4xRAYS/VOLK racing mesh 16x7",16x8"
    4xSSR Formula Mesh 15X7"
    2xSSR Precedeo 15x7"
    2x Advan Oni 15x7.5"
    4x Longchamp XR4 15x6.5"
    4xSSR Mesh 15x6.5"
    Suspension:
    Front:
    Jap AE86 Struts modified to Short Stroke and fitted with Coilover Height Adjustment, Jap strut tops, TRD springs, TRD short stroke shocks, Cusco Type OS Strut Brace, Stock castor rods adjusted to max castor,
    Rear:
    TRD Springs, spring rubbers removed, TRD Blue 8 way adjustable short stroke shocks. Whiteline Adjustable panhard rod, Cusco Rear strut brace, Alloy A-Spec Brace with harness mounts
    Interior:
    Entire car has been stripped of sound deadener and most interior trim. saves around ~20kg apparently.Relocated battery, 4 point Half Cage, Drivers seat is Eva Imsa Fibreglass fixed back on Bride rail, Passenger seat is Recaro on custom rail , Nardi steering wheel, Super long boss kit, Jap instrument cluster, Autometer monster tacho, Omori oil/water temp gauges, Tomei Boost gauge, Sparco carbon fibre pedals, No stereo.
    Exterior:
    Early model Levin taillights, Jap Late model headlights, indicators and foglights
    Weight (with 4age): Weighbridge verified ~ 920KG with no rear seats, tools or spare.
    woohoo finally ian
    cant wait to see it in the flesh
    Ian
    NOR
    haha yeh
    will be heading up to drift practice, but not entering
    come check it out then
    Senior Member 4agtezza's Avatar
    Eireann
    Everton Hills
    whens that on?
    86's for over 10 yrs...
    KAWAII_hachi_roku
    Post
    i like the burnout photo!
    Ian
    NOR
    drift practice 10/3
    Veteran breno's Avatar
    Feb 2010
    Brendan
    Queensland
    Stafford
    looks sweet man, well done
    ok, but you'll have to show me before the drift starts because after it does im not leaving the track for anyone
    ....unless you are going to be there all night
    Brad
    Central coast
    looks good!
    have you had it dynoed, if so what power is it putting out?
    is that burnout pic at the drags? what time you run?
    how is the t18 diff holding out?
    Ian
    NOR
    no dyno yet
    burnout pic from motorvation hence no drag time
    jap diff is holding up good so far
  1. Tsuchiya's AE86 and Itsuki's voice actor
    By AE86.cn in forum Toyotas in the Media
    Last Post: 8th June 2008, 04:08 AM
  2. AE86's, 4AGE's, engineering and Victoria
    By parrot in forum Technical - Questions
    Last Post: 25th December 2007, 01:08 AM
  3. Next Hachi Cruze???'AE86 Driving Club' Stickers???
    By Dan_AE86 in forum General Topics (No Technical Questions)
    Last Post: 8th April 2007, 06:32 PM
