Results 1 to 4 of 4
Thread: 4AC Throttle
    Senior Member LEVIN86's Avatar
    Nam
    Westside
    Default 4AC Throttle
    Hey all
    my 4ac motor has been driving fine and after cleaning the filter ive notices that the throttle doesnt close completely ..
    just wondering how does this affect the car .. is it something i should be worried about ?
    hope this makes sense .. ill try get some pics up
    Nam
    Jonathan
    On a carby, the thottle never closes completely. It is help open slightly at idle, and you adjust this for idle speed.
    On EFI the throttle closes completely.
    Dave
    does it idle any higher?
    the throttle will be open a little bit...to allow air to get in so that it can idle.
    all that the idle screw on your carby does is open up the throttle a little bit to allow Some air in, jsut enough to make it sit at 1000rpm or so.
    so in short...no it wont make any difference to your engine assuming its not idling to high. if the throttle gets stuck open then it will just idle high when you dont have your foot on the accel at all. which would be a problem.
    you can make the throttle close all the way if you want, but it wont idle at all!
  • #4
    Nam
    Westside
    haha sweet guys .. car idles fine so i guess its all good
    thanks for the help
  • Similar Threads
    1. Throttle cables
      By kaneO in forum Technical - Questions
      Last Post: 22nd November 2007, 12:41 PM
    2. throttle cable
      By kaneO in forum Cars or Parts Wanted
      Last Post: 15th November 2007, 08:08 AM
    3. 4ac's or 4ac bottom end
      By xero in forum Cars or Parts Wanted
      Last Post: 13th June 2007, 05:34 PM
    4. Throttle Bodies
      By 4AGE - 86 in forum Technical - Questions
      Last Post: 24th March 2006, 05:42 PM
    5. throttle bodies
      By Insane in forum General Topics (No Technical Questions)
      Last Post: 19th July 2005, 04:41 PM
