Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: turbo experts 4agte
    Reeece
    Casula
    Default turbo experts 4agte
    Hey guys i am just wanting to know if this is a big turbo for 4agte. Ive got my t28 turbo hiflow to this and it seems to be very lagging ..I am leaning towards actuator is faulty but i am getting full boost at 6000rpm in 1st 5200rpm in 2nd/3rd so its seems weird when the suppiler rekons i should be full spooling by 4000rpm
    Ive check for leaks and removed my MBC but its still not boosting properly.. I am using a stock 7psi t28 actuator that i put on with not knowing the condition before hand. It opens fine but might be opening under boost pressure to easy ? causing it to lag all the way to high boost
    SO any info is appreciated
    Comp wheel:
    T3 super flow wheel
    48.3 inducer, 60mm exducer, 12 fins 6long 6 short Trim 65
    Turbine:
    65mm TB34 11 fin turbine wheel,
    Internals:
    T04E 360 degree thrust bearing
    Senior Member dave2221's Avatar
    ahhh i know the problem....
    need to add more boost.... i think i run about 86psi on my turbo.....
    :p lol
    Mason
    Salisbury East
    Hey mate
    How much boost does it get at 6000 rpm?
    What size is the A/R exhaust housing?
    Should be cast on the outside or stamped on the inside.
    To check wastgate diaphram, suck on the hose to it
    then block it with your tongue and check if it holds vacuum.
    If it holds vacuum then adjust the actuator thread so it's
    a bit shorter then test drive. If it gets more boost sooner
    keep winding till it reaches your max boost level.
    See how you go
    Reeece
    Casula
    hey mate thanks for your quick reply.. I am only boosting 10psi.. its a .64 housing but hiflow obviously.. What do you mean by that.. stick a hose onto it and block the hose to see if the actuator has a vaccum ? Also this actuator is none adjustable via thread. Should i upgrade to a 14psi actuator ?
    Mason
    Salisbury East
    Fit a vacuum hose on the actuator long enough
    for you put it in your mouth, then suck on it to
    create some vacuum then block it with your tongue
    for about a minute. If it pulls vacuum and holds
    it you will know when your tongue gets sucked into the hose.
    If the actuator is faulty it won't suck your tongue into the hose.
    You have to check the actuator first before you go out and buy a new one
    to pinpoint the problem. It could be that the actuator has got enough tension
    on the wastegate flap, is it hard or easy to open the wastegate flap?
    Gunner
    you need to add pressure via the vacuum line, usually by using something like a cooling system pressure tester.
    This way, you can see what the actuator is doing under boost, what happens under vacuum is irrelevant, unless it is a dual diaphragm actuator
    Reeece
    Casula
    its seems pretty stiff when using hands on the rod to pull it open ill try this tomz thanks mate .. Stressing
    Reeece
    Casula
    ill nitro test it tomorrow using gauge lines.. I am hoping that its f$cked or i am f@cked for having such a laggy turbo.. Anyone got some insite on the specs of the turbo ???
    Gunner
    test the actuator, all your cooler pipes, anything boost related, do a comp test, if all is ok with that then take your turbo back to the dude that did it, and tell him it doesn't work.
    As for size, i can't comment. I don't know whats done to it.
    Gunner
    better yet, get a good tune, that might wake it up.
  1. 4agte turbo manifold
    By ke70drift in forum Car Parts For Sale
    Last Post: 23rd August 2010, 03:18 PM
  2. 4agte power figures? which turbo?
    By Nic19 in forum Technical - Questions
    Last Post: 15th March 2010, 10:50 PM
  3. 4AGTE - What turbo do you use / suggest?
    By stahlz_ae86 in forum Technical - Questions
    Last Post: 26th August 2009, 02:36 PM
  4. 4agte turbo options.
    By cotts13 in forum Technical - Questions
    Last Post: 29th March 2009, 12:47 AM
  5. 4agte turbo
    By spillman in forum General Topics (No Technical Questions)
    Last Post: 9th December 2007, 09:05 PM
