I would be trying your acctuator, that is the exact problem that I had with mine not two days ago. It looks like everything is great and good to go but the reality is that it was open just a fraction and that was all that it needed. I adjusted the actuator rod and it was good to go, back to doing what it should be. Even with a highflow you should be seeing some boost before 5500rpm. The other thing that you have to think about is the fact that because we have the ZE engine it will be slower coming on boost than the equivilent GE engine with the same turbo and boost etc. This is because the lower compression ratio means that there is less BMEP generated by the engine at a given rpm.
Paul
