Results 1 to 10 of 14
Thread: Building a 4age - Pistons
    Sep 2009
    Decided since there's little on the net about resembling a 4ag(z)e
    So this is just one part of it. Resembling the Pistons - Note for 20mm guden pin with circlips (gze)
    What you will need.
    You pistons
    Small nose pliers
    Hot plate and sauce pan
    Thermometer
    Old rag
    Hammer
    Bash rod
    Oil
    15min per piston
    What you need
    Sep 2009
    1: Heating the piston.
    You have to heat the piston to 70-80oC for the pin to go in.
    Wile you wait, you can find the front of the rod.
    Sep 2009
    There will be a raised point near the crank end. (Dot) This is the front, the front of the piston is the arrow, you match them... rocket science here.
    Sep 2009
    But before you put the pistons in you will want to install one of the pin things,
    Grab them with you pliers
    Yes i know mine arnt long nose nor pliers
    Sep 2009
    Sep 2009
    Now after you piston is nice and steamy, bring it out and lube out the Pin with some oil, them gently tap it into the piston.
    Just after it exits one side, put the rod in making sure it facing the front, then punch the pin in some more, making sure the rod doesn't fowl
    Keep going until its complete inserted.
    Once in reinstall the other clip and done.
    How easy was that!
    Thurston
    Vic
    North East
    "Pin things" = circlips
    Nice guide, look forward to the next installment.
    Veteran slydar's Avatar
    Dimitri
    you need to mention which variation of piston/rod combo this is. i.e early 18mm press fit, or later 20mm floating.
    i know theyre gze pistons. so they have to be 20mm full floating, but i think you should put that in the title or something.
    78's
    Sep 2009
    yeah i was told about that last night, updates
    Ted
    Jason, dont let ya mum catch you cooking pistons in her pots !
    lookin good.
  1. 4age RWD bits, 5ag pistons, trd leads, 4age coil/igniter
    By slide86 in forum Car Parts For Sale
    Last Post: 16th February 2012, 04:58 PM
  2. Installing Pistons - Building a 4age Part #3
    By jason in forum Technical - Articles
    Last Post: 18th May 2007, 05:59 PM
  3. Building a 4age - Valves
    By Rich_86 in forum Technical - Articles
    Last Post: 7th May 2007, 04:38 PM
  4. Building a 4age - Crank
    By machg in forum Technical - Articles
    Last Post: 21st October 2006, 07:18 PM
  5. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
