4AGZE fly wont fit in a T50
Its that enough or do u want more?
super quick question, (because i couldn't be bothered to walk outside an ask)
Is it possible to fit a 4agze 225mm flywheel off a AW11 into a Silver top 20v.
From memory..
Silvertop 20v's have a 212mm fly and 4agze have a 225 fly (both 8 bolt)
im not sure what the pros and cons would be of putting the bigger fly in, (even it does fit)
Thanks
Nah thats fine..
Thanks
Yes it will fit a T50. You just need to grind the T50 bellhousing a little and it will work.
Sprinter Veteran
Whats the benefit of running a larger fly wheel?
You can transfer more torque through the larger clutch
Sprinter Veteran
However you won't be pushing the limits of a 212mm flywheel and decent clutch with a 20V unless you do a serious turbo conversion to it.
ZE (224mm) flywheel is meavier than the 212, so I'd say don't do it.
thats true biggo
the input shaft on a GZE is the same size as those on the W series gearboxes. if your putting out enough power to require a larger flywheel then you will need to upgrade your gearbox becasue you will blow a t-50 to peices.
there are plenty of guys running 200mm flywheels with decent clutch setups on their 4AGTE's and some have a bit of slip some dont depends on which pressure plates and clutch plates they use.
bigger isnt always better.
Yeh it is but you get a clutch plate out of a toyota dyna truck, it has the same diameter as the GZE clutch but the same spline as a T50 gearbox.
Sprinter Veteran
