Results 1 to 4 of 4
Thread: Common Problem AE71/KE70 Headlight/indicator Switch
    Veteran stahlz_ae86's Avatar
    Paul
    Default Common Problem AE71/KE70 Headlight/indicator Switch
    [Info copied and pasted from thread I made on Toymods ~ 3 years back]
    Hope this thread can be useful to any KE70/AE71 owners who encounter this common problem.
    A few months back whilst driving at night I noticed my headlights cut out every time the automatic release flicked the turn signal off after i was pulling out of a corner. Initially I thought little of it, yet it continued to occur so I went to pick a part and bought another switch cluster unit and replaced it. Yep you guessed it, same problem.
    Long story short, dad has an old mate (auto elec) who confirmed this model corolla has this common problem. As time goes by and the indicator switch is repeatedly used, the wires within that lead to the headlight switch get worn out as they kink over a plastic "lug" causing the wire to break as it is only three thin wires.
    I fixed the problem by running three new wires down the indicator stalk to replace the broken wires. If you do encounter this problem and take the unit out you will see what i mean, and hopefully i have helped out and saved you the trip to the wreckers
    PS: As the warranty on the part at the wreckers was only a few dollars extra i did pay it and they gave me a parts credit when i returned the dodgy unit. So when it comes to electricals i also suggest you buy your parts with warranty. Hope this is helpful.
    This is the unit out of my KE70 parts car
    Where it is circled is where the breakage is on this one....
    ....from memory when i repaired mine, the breakage was further along the wire somewhere, but either way these are the wires i replaced (right through)
    Paul
    Senior Member Sturgey's Avatar
    Jarrod
    Launceston
    thankyouuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
    never though of that lol
    1984 ae71 Panelvan - Sold
    2000 Lexus IS200 - Cruiser
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    ahaha thats why! i thought i was turning them off LOL!
  • #4
    Senior Member addikt's Avatar
    Tyson
    my m8s does this also ill have to let him know cheers man
    Old username : hally
    Beige build in the works!!
    http://www.ae86drivingclub.com.au/fo...426#post874426
  • Similar Threads
    1. Looking for an AE86 indicator stalk/switch assembly
      By ToySprinta in forum Cars or Parts Wanted
      Last Post: 2nd December 2011, 03:51 PM
    2. headlight switch
      By khai2298 in forum Technical - Questions
      Last Post: 15th September 2009, 02:18 PM
    3. ae71 / ke70 indicator/headlight stalk
      By seek in forum Cars or Parts Wanted
      Last Post: 7th March 2009, 09:59 AM
    4. headlight switch
      By Rich_86 in forum Car Parts For Sale
      Last Post: 22nd November 2007, 09:44 PM
    5. headlight switch
      By not for show in forum General Topics (No Technical Questions)
      Last Post: 18th October 2006, 08:32 AM
