Results 1 to 10 of 12
Thread: Differences between n/a bigport head and gze bigport head
    Nat
    Newcastle
    Ok, it looks like I might be purchasing a 4agze head, which I had intended to be part of a mongrel bitza n/a motor I'm going to build. I was just wondering what differences there were between the n/a and sc versions of the bigport head? I searched and found out the cams are different but couldnt find any other info.
    Thanks guys!
    From what I have been able to find, the only difference is the cam covers. ZE says "SUPERCHARGER" GE doesn't... suprise suprise.
    EDIT after some research - Also the cams MAY be different. Apparently it is only the early "Bluetop" bigport 4AGE that has the 7.56mm lift 240deg cams.
    Nat
    Newcastle
    Thanks for that hen.
    The cams aren't massively important cos i intend to change them later anyway. Supercharged cam covers on an n/a car could be good for a laugh anyway, haha
    Jul 2009
    cams..
    GZE bigport are the same as GZE/GE smallport 232deg duration, 7.1mm lift..
    GE bigport are 240deg duration and 7.56mm lift..
    Matty, I've heard that said before, though it ended up being strongly debated.
    Where did you get that info from?
    Jul 2009
    you can pyhsically notice the difference.. the 232's are really sharp on the top of the lobe, and the 240's are noticibly smoother.. or you can just check part numbers
    13501-16030 - 232's intake
    13502-16020 - 232's ex
    13501-16010 - 240's intake
    13502-16010 - 240's ex
    hope that helps
    Jul 2009
    i have cut and pasted random info in word documents over time.. but i think that there was a big write up in the tec section of club 4AG...
    Nat
    Newcastle
    Yeah, I read on billzilla that the cams were different. Thanks for clearing that up matty.
    Senior Member stouty's Avatar
    Leigh
    Forster
    If you get Drift Battle Number 7 it has a write up of all the differnt AE86 engines that people use and the differences between the engines.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    I wouldn't trust that writeup as gospel. It also seemed to pull a lot of info from Phil Bradshaws 4AGE page (though there are many others out there also with good info)
  1. Replies: 6
    Last Post: 15th October 2012, 06:02 PM
  2. Bigport head differences?
    By JDM-086 in forum Technical - Questions
    Last Post: 8th September 2012, 07:16 PM
  3. Bigport head
    By EVOSTi in forum Car Parts For Sale
    Last Post: 14th October 2011, 08:13 PM
  4. Bigport Head/ Bigport Engine Briz
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 18th January 2011, 01:28 PM
  5. what is this off with a gze bigport head
    By xwfalcon in forum Technical - Questions
    Last Post: 26th May 2008, 07:12 PM
