Page 2 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 11 to 20 of 124
Thread: things from other cars that replace stock sprinter bits
  1. #11
    Veteran driftism's Avatar
    Andrew
    Watsoia
    what model laser is this?? KE,KB, KC??? KFC???
  2. #12
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    not sure just check have awalk around in some wreckers! always interesting
  3. #13
    Andrew
    Watsoia
    daihatsu charade (84ish model) door locks are exactly the same as sprinter ones. you just need to take them to a locksmith and get them keyed alike.
  4. #14
    Alex
    St Lucia
    I heard that the front panels of AW11s are the same as truenos (bonnet, guards and lights).
    Dont know if its true or not but yeah...
  5. #15
    GoldCoast
    has anybody tried a dash from another car yet. cuz so many people want good nic ae86 dahss but there just arnt any.
  6. #16
    Oldschool Member
    May 2005
    tadd
    nsw
    bh
    aus
    is it real? for passenger side as well?
  7. #17
    Senior Member DavisJD's Avatar
    Just some basic things you can look for at wreckers to neaten up your hachi a bit.
    If your rear hatch struts are broken there are a couple of different Toyota models with the same struts, just check the model code as there are different lenghts that look similar. Getting your struts re-gased isnt that expensive though if there not broken.
    The glass covers on the headlights are the same as on a few different same generation Toyotas, not sure what models.
    Same goes as above parkers and indicators, may be slightly different to line up screws, havent checked yet.
    Same goes as above for seat rails.
    Theres a heap of interchangable parts between the Toyotas, if your after something specific just go to a wreckers and have a look.
  8. #18
    Will
    do you guys want to keep this thread to things you personally know will fit? rather than spread mis-information and heresay?
    i mean trueno panels and Aw11 panels interchangable? paleeeese!
    one i know works, KE70 strut tops bolt into an AE86 and give you more caster
  9. #19
    Not sure if your talking about my post or not, if you aren't just ignore this.
    But anyway, i know from 1st hand experience that the headlight glass covers and the seat rails are interchangable, i didnt list specific models as i simply dont remember, its not that hard for people to look a tthe parts and work the rest out for themselves. I was simply trying to help those that might not know the benefits of searching at a wreckers.
    Again, you might not be taling about my post, but it just seems u were as it was after my post
  10. #20
    Will
    nah don't worry davis, wasn't targetting anyone, just specific first hand info is a big help!
    and no offence to flamingheads either but all you need to do is look at the two cars, they are completely different!
  1. things from other cars that replace stock sprinter bits
    By Jonny Rochester in forum Offtopic Discussions
    Last Post: 9th January 2007, 10:41 PM
