Page 3 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 30 of 124
Thread: things from other cars that replace stock sprinter bits
  1. #21
    Mar 2010
    Rory
    Well I heard from a mates cousin who's friend's girlfriend's brother says that you can drop the entire running gear from an R34 GTR straight into an 86 bolt for bolt..... I'm saving up as we speak...
  2. #22
    Sep 2005
    hahaha
  3. #23
    Jan 2006
    ArJay- You are a killa.. lmao
  4. #24
    Oldschool Member
    Aug 2005
    twincam FWD corrola petrol tank fuel pump mount will bolt right into a sprinter tank, with breather, and wires for fuel pump. pump will need to be mounted lower and will surge terribly under 1/4 tank, but it works.
    Someone told me sv21 fuel pump and mounting fits.... it doesn't... and it doesn't have a breather either. so don't use that one, unless you like drilling new holes for the bolts.
    and remember kids, when wiring the fuel pump up, make sure it isn't just wired to the ignition, you want it to stop pumping fuel everywhere when the engine stops running (ie. crash).
    I hope this FIRST HAND information is of some help.
  5. #25
    Senior Member gg004's Avatar
    Glenn
    Queensland
    Gold Coast
    some1 told me the same fuel pump from MA60 supra bolts into AE86 tank is this true?
    2013 Toyota 86 GTS 4U-GSE
    1983 Toyota Sprinter AE86 4AGTE
    1967 Toyota Corona 1600S Coupe RT51 4R
  6. #26
    Scott
    ACT
    Braddon
    bracket will need 45mm added to its length... this will situate the pump on the bottom of the tank.
  7. #27
    tye
    nsw
    wollongong
    I use to have a ae101 dash in my ke70 ..looked shmik but isnt straight bolt in ..need to slighly cut down ends and also weld new tabs in just under windscreen for dash to clip into .
  8. #28
    180, mr2 & trueno hav the same headlight lens
  9. #29
    Veteran driftism's Avatar
    Andrew
    Watsoia
    and RA60/st162 celicas do too
  10. #30
    Oldschool Member
    May 2005
    tadd
    nsw
    bh
    aus
    hiace too
  1. things from other cars that replace stock sprinter bits
    By Jonny Rochester in forum Offtopic Discussions
    Last Post: 9th January 2007, 10:41 PM
