what can replace stock 86 seat rails besides the starlet ones?
Well let's see.
I'm talking back in 1992 when I did my coversion but I sourced a Camry fuel pump. Same as a ae82. BUT, I think the connectors from the pipe to pump are different. Fuel filter looks the same but if you used a OEM t/c 86 fuel line the threads are different. I hate having to get a new fuel filter as I always get them mixed up.
I have read it in too many places and also heard it from my suspension specialist back then the '83 Supra's shocks fit the 86. More to the point, Toyota sourced it from the Supra's parts bin.
You will also notice a lot of interior trim parts are also general bin sourced too. Air vents ,switches etc.
ke70 ***BUT**** double check seat rails as there are differences in ke70 1's i had a seat out of a square headlight 1 (early ke70) different setup (ie sliding mechanism and slightly different mounts, but found a shovel front (late ke70) with what looks to be identical to an ae86 setup but just slight differences such as handle covering ect
so ae71 rails?
If you put in a 4AGE bellhousing with the slave on the drivers side, an RA60 solid clutch line is an exact fit.
Pulled a few things off a wrecked RA60 Celica today that bolt on for an 86..
- Rear hatch struts
- Number plate lights
- Windscreen washer pump + bracket
Got all these for $20
If your fitting AE86 struts to an AE71 and can't find AE86 steering arms corona ones will work.
AE71 strut tops in an AE86 gives you more caster ( swap left to right)
To use AE86 camber tops in an AE71 pull the slides off and invert all the studs and assemble. The vernier readout is gone but it saves you running out of adjustment on stock AE71 caster bars.
JDM tanks work in an AE71(some mods) and so vice vera.
Bigport water pumps work on 20V's with a few washers on the mount for the altenater adjuster
Landcruiser and cressida throttle cables work for bigport(slightly long) and 20V installs
sigma rear wheel studs so u can runn slide on spacers! 10mm longer than 86 and t18
I've just done these. I think David Lawson may have posted this earlier in the thread. Interestingly I had two different size studs on my AE86. The sigma studs are either 8mm or 6mm longer in my experience depending on what you already have. I looked at a variety of mitsubishis and nearly all the 4 stud cars run the same wheel stud across a few generations.
