Brand New HSP 2009 1/8 BATTLE 2009 Nitro Gas 4WD Truggy
Not a drop of fuel in the car $450 + $20 postage anywhere in Australia with registered post
Located in Melbourne S.E Subs
Call or SMS me :0433180340
Up to 80kph+ Speed
Buggy is Ready To Run.......
-Full Assembled Aluminum Chassis with Protective Skirts Complete with Painted Body, & Everything Installed.....
-Powerful SH.PRO.18 Engine Equipped With Slide Carburetor And Pull-starter.
(1.6hp/34000rpm has more power than the CXP.21 Engine in HSP Bazooka)
-Larger Hi Flow Air Filter.
-Aluminum Racing Shocks
-Feature Rear Down force Wing
-Differential With Built-in Front And Rear Bevel Gears.
-Sway Bars Front and Rear
-Adjustable Double Disc Brake System
(you can distribute brake to front and rear wheels)
-New Center Gear (much stronger)
-High Traction Radial Tires.
TECHNICAL DATA:
Length 515mm
Width 385mm
Height 210mm
Gear Ratio 1:11.1
Ground Clearance: 42mm
Wheelbase: 325
Tires 130 mm 85mm
Weight 3000g
Package inc:
HSP 1/8 BATTLE 2009
Instruction Manual
Transmitter : HSP 2 Channel AM Digital Proportional With Throttle/Steering Trim, EPA Adjustment with Instruction Booklet.Requires 8 x AA Batteries
You will require: Nitro Fuel (available at any Hobby Stores for 10/L) and Glow Igniter
