Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 32
Thread: Xt130 struts brake upgrade
    Senior Member Ksevn-T's Avatar
    Default Xt130 struts brake upgrade
    hey guys,
    Have the whole xt130 suspension setup in the front of my ke. I heard somewhere you could put cresida Mx73 or 63* disks on (straight bolt in), to run with corona calipers? Advantage being that cresida disks are vented.
    Cheers,
    Alex
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    peugeot 604 rotors, hilux LN106 4wd calipers (late 80's to mid 90's shape), and a landcruiser (i think) master cylinder. 4 spot brakes and massive stopping power awaits. If you want a more detailed guide i have a step by step thing saved on my other computer. PM me if you want
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by Ksevn-T View Post
    hey guys,
    Cheers,
    Alex
    The upgrade you are referring to is the following
    XT130 Struts
    RA65 Rotors
    MX62 Calipers
    5mm washers
    5mm longer bolts.
    There's a thread on toymods about it.
    From memory, you drill out the thread on the strut and put the washer in between the strut and caliper, but best double check.
    Veteran slydar's Avatar
    Dimitri
    Quote Originally Posted by Javal View Post
    XT130 Struts
    RA65 Rotors
    MX62 Calipers
    5mm washers
    5mm longer bolts.
    i have this set up. it isnt quite that simple.
    youre right about the drilling out of the threads on the caliper bracket (part of the stub axle on the xt strut)
    but the inboard side of the xt bracket is not flat. it needs to be milled flat. its a bit tricky to set up in the bed of the mill too. and the steel is quite hard (which is good i guess). the spacer size depends on the amount you mill off.
    ill post some pics later.
    Senior Member resol's Avatar
    steve
    vic
    why do you need to upgrade the twin pots for a corolla wagon? better tyres would make more of a difference!
    vented rotors dont give you more stopping power, they just dissapate heat more, which if your REALLY pushing it will mean the brakes are more consistant after heavy extended use.
    if you want more stopping power try better pads, slotted rotors, or better tyres
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Josho
    Quote Originally Posted by resol View Post
    -dan
    Slotted rotors won't do a whole heap. Pads yes, and a god damn brake flush and bleed will do a world of good. however brake fade can still be an issue, which is why i'm looking into a vented upgrade for my bucket.
    Quote Originally Posted by slydar View Post
    I'm very interested to see this. Still tossing up between this and the pug hilux upgrade.
    beau
    Bathurst
    just a thought, can you split the corona calipers? coz if thats possible you could make up some spacer plates without to much drama and just run a vented version of the stock disk (need to check a rotor catalog for that info tho)
    Veteran Konakid's Avatar
    Henry
    Eastern
    SR rolla, very interested in the details of the Pug hilux setup, PM me please!
    Would a a standard RT142 corona MS be big enough for this upgrade? Unsure on its size.
    Josho
    Quote Originally Posted by sr_rolla View Post
    Corona caliper does not split, it's a D frame and caliper assembly, same as AE71 / AE86. RA65 rotor would be a close fit to this application, they are 3mm smaller diameter than a corona rotor, but vented.
    Josho
    Should be stamped on the master. From memory it's 15/16".
    It should accept the same m/c upgrades as the Ae86.
  1. Replies: 6
    Last Post: 10th April 2011, 03:56 PM
  2. Replies: 7
    Last Post: 2nd September 2010, 05:46 PM
  3. brake upgrade using ae86 struts
    By kerola in forum Technical - Questions
    Last Post: 26th August 2010, 10:54 PM
  4. xt130 brake upgrade
    By trikzlane in forum Technical - Questions
    Last Post: 27th December 2009, 07:13 PM
  5. hilux xt130 brake upgrade
    Last Post: 6th June 2008, 10:17 PM
