Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 114
Thread: Oly's 7AGTE Hatch
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    Talking Oly's 7AGTE Hatch
    Hey guys
    The car is a ADM 1984 Sprinter, I picked it up a few years ago, and since then have been slowly making progress. Drive it to work everyday and also some track/skidpan action every now and then.
    Under Bonnet: * New Spec*
    - 20V AE101 ST Head - J Works Ported (Thanks Seamus), Ivan Tighe Custom Cam ~ 270/280 Duration, Toda Valvesprings, ARP Head Studs
    - 7AFE Block, Oil squirters installed, rebored, balanced rotating assembly
    - Wiseco Pistons - Teflon coated skirt and top, Forged I beam rods - ARP Bolts
    - Toda 4.4kg flywheel - ARP Bolts + Alloy crank pulley
    - 7AFE Oil pump, 20V ST Tensioner + Gates T980 Timing Belt (Peugoet 205)
    - Custom Polished 20V Inlet Plenum (Thanks Ant @ KZG)
    - Turbosmart FPR800 Adjustable Fuel Reg
    - Trust TD05-16G Turbo Kit with External Gate *Screamer*
    - Trust Type R BOV
    - Mitsubishi Evo7 FMIC
    - 440cc 2J Supra Injectors
    - Greddy Thermostatic Oil Cooler
    - MoTeC M4 PRO ECU running 4 Coil Ignition
    - Twin Core Alloy Radiator with 13’’ Thermofan
    Interior:
    - Nardi Deep Corn Steerer = TRD Knob
    - Mitsubishi FTO Seats
    - Greddy Profec BII Boost Controller
    - Clarion USB Stereo
    - Autometer Water temp, Oil temp, Oil Pressure and Boost Gauges
    Mechanical/Brakes:
    - Exedy HDCB Clutch with TRD Pressure Plate & Braided Line
    - T-18 Diff, Tomei 2-Way LSD with 4.1 Ratio
    - W58 Gearbox with AZ Custom adapter
    - RX7 Front Calipers, Mini Cooper S Rotors and Braided Lines
    - R32 GTS-T Master Cylinder
    - 3 Inch Dump back zoorst with Magnaflow metalcat and hi-flow muffler
    - Surge Tank with Bosch VL Turbo Pumps
    Suspension, Steering:
    - Front- Kaizen Garage Coilovers, KYB AGX inserts, 6kg Spring, T3 Cambertops
    - Rear- KYB AGX Shocks, 4.5kg AJPS Springs
    - Quaife Quick Rack with PS Arms
    - CMR Hollow Front Swaybar
    - Whiteline Rear Adjustable Swaybar
    - Whiteline Copy front strut brace
    - T3 RCA’s
    - Whiteline Adjustable Panhard Rod
    - Urethane bushes all-round
    Body:
    - Origin Stylish FRP front bar
    - Flared front guards (thanks Dim @ Custom Compact)
    - JDM Kouki Headlights
    - East Bear Electric Mirrors
    - eBay Special Smoked Tails with Whiteline Centre
    - Kouki Levin Grille and Foglamps
    - RS Watanabe 15x8.5 -6 Wheels
    - Bridgestone Potenzas Re001 195/15
    - 20% Window Tint
    Future mods (when I have the cash/motivation)
    - Some sort of cage - maybe
    - Adjustable Rear Trailing Arms
    - Rose Jointed Radius Rods
    Oliver
    Logan Shire
    When I picked her up, had a std 20V and some basic suspension work but was soo much fun, upgrading from 4A-FC FWD Corolla
    Oliver
    Logan Shire
    Then I found some wheels on eBay USA, took a while but eventually they came And picked up a TopStage front lip, know deceased.
  • #4
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Me rikey this car, makes me happy in the groin.
    Looks good man, looks even sweeter when I see it driving.
  • #5
    Member 86JAP's Avatar
    Port Macquarie
    Looks tops mate.. hope to see it on the goldy sometime..
  • #6
    Oliver
    Logan Shire
    Yea, drive to the Goldy now and then, love the Levin Notch, wish I knew about them before bought mine
  • #7
    Veteran Wally's Avatar
    looks great mate!
    4AGE 16V
  • #8
    Oliver
    Logan Shire
    I threw in a newer 20V, and got some trumpets for increased intake roar Got over 100 dB under the bonnet with these puppies.
  • #9
    Oliver
    Logan Shire
    Then when the ADM brakes got tired, put together some RX7 calipers and Mini Rotors. Difference was dramatic.
  • #10
    Oliver
    Logan Shire
    Then I got bored with the std 20V and wanted a bit more rush. I slowly bought the bits then took her off the road for 3 weeks. 4 Months later I was off to the tuners
    Definitely more satisfaction doing the work yourself at home, just takes longer.
  • Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. 7AGTE 20v TE71 Sedan Track Car build
      By Sprinter86 in forum KE70 / AE71 Owners Forums
      Last Post: 11th May 2018, 12:30 PM
    2. Replies: 8
      Last Post: 13th September 2012, 04:30 PM
    3. ke70 7agte
      By shayden in forum KE70 / AE71 Owners Forums
      Last Post: 11th January 2012, 09:38 PM
    4. ST or BT 20v for 7AGTE Build? Keep vvt?
      By PRIMRK in forum Technical - Questions
      Last Post: 13th September 2010, 07:03 PM
    5. ae86 doors, rear bumper, hatch, drivers side gaurd,hatch
      By nos_86 in forum Car Parts For Sale
      Last Post: 9th August 2008, 11:54 AM
